@Richard19068
I do not varnish my hand rails. I just give it a coat of teak oil once in a while. If the cap nuts get a little stain on them, I just wipe it off before it gets to dry.
The SEADEK is easy to apply. You need to be carful around it when walking on it. Soft shoes or barefoot is best. I laid down a tool with a sharp edge and somehow it must have been stepped on or something and it left a mark. Application: make sure the surface is good and clean, peel and stick, use a roller to get good adherence. I got really lucky with about a 98% accuracy of getting it in the correct position. I don't think you can lift and stick again after the initial contact.
