New to me, 1999 Catalina 320 with Yanmar 3GM30F diesel engine. I want to make sure that my check list is correct:
1. check engine oil (dipstick)
2. check raw water strainer under the fuel filter
3. Open the raw water seacock under the galley sink (is that the right location)?
4. check fuel level
5. switch the main AC breaker off (the main switch for 120 volts)
6. turn off shore power at the dock power tower. Unplug the shore power cord from the dock outlet
7. unplug the shore power plug from the boat
8. Perform a battery check on Battery 1 and Battery 2.
9. Set the battery selector switch to "1"
10. Switch 12-volt DC switches ON for departure: navigation/communication. The bilge pump switch should be on at all times.
11. Check the reading on the depth instrument.
12. Release the steering wheel brake
13. Shift the lever to NEUTRAL position before starting the engine
14. Ensure that the engine cooling water seacock is OPEN (under the galley sink??)
15. Again, double-check that the gear lever is in NEUTRAL
16. Turn on the blower fan for ??? minutes
17. Turn off the blower fan
18. Put the key in the ignition and turn
19. Push the button to start the engine.
Did I miss anything? How many seacocks do I have on my 320?
thanks -madmax
4. check fuel level
thanks -madmax
