Maybe I missed it but the last thing to check is after the engine starts, look over the stern and make sure water is coming out of the exhaust. Also, familiarize yourself with how to clear a clogged raw water line. Mine would usually occur right at the point where it was injected into the mixing elbow due to salts building up. It would require removing a little bronze elbow and reaming it out with a screwdriver. Same thing inside the hole in the mixing elbow. Sometimes it was due to a clog at the seacock. Pulling the input hose at the seawater strainer and using my air horn to blow back (2 honks) through the line usually worked.
