Hello and thanks in advance for the input and suggestions.
I am looking to demast a 96 H336 and use it for the ICW and lakes ,rivers,canals along the way under 100% solar electric power. I have already installed the electric motor and solar panels.
*My main question is once I take the mast down should i cut the keel and rudder down a bit too? I would rather not worry about getting hung up on the keel/ruder in low depths if their is no need for the deeper keel and rudder as this boat will NEVER be used as a sailboat again due to the solar and future mods. From what I have been told the boat will rock pretty good even in somewhat calm water if it's kept stock due to ration difference in the ballast weight from the mast removal.
Second question is about installing an outboard motor and jackplate for backup/secondary propulsion. Has anyone ever done this or seen this before on an h336 or similar model? IT seems possible to install a transom (see pic) by removing the 2 tiedowns circled in blue and bolting a homemade transom in place
* I got the boat dirt cheap and already pot committed, so I am not worried about : ruining a good sail boat, the resale, buying a cabin cruiser instead etc etc etc lol
