Hello,
I cant seem to get a good answer for my issue as its a little complicated. Need a good final (bottom coat?) paint to finish the keel. 1971 Cataina 22 swing keel. Old owner passed years ago so I have not idea what kind paint he used on the keel... but also don't want to re-do the entire keel as 80% of it is fine... 20% of the top is rusted.
Will be on a a freshwater lake in PA for 7 months out of the year. I don't race and this is the hard part of the keel to get to, so I'd like to not have to take my keel the whole way off every year to repaint it.
Also does this process sound like a good plan.. I will be doing as soon as I know what bottom paint to get. I already have all the products which I mention so this is what I'll be using for everything, except the final bottom coat which I dont know what to get for that.
The process....
1. Hammer, scrape and grind all rust parts down to shiny metal. then immediatly....
2. Clean with total boat dewaxer and surfice prep.
3. Apply total boat rust primer...
3a. clean and/or sand before next step?
4. Apply 1 coat totalboat Totalprotect Epoxy Primer
4a. clean and/or sand again before next step???
5. Apply Totalboat Total fair to fill holes and make all smooth.
5a. clean and/or sand again???
6. 3 more coats of totalboat Total protect expoy primer
6a. clean and/or sand again???
7. Then a final coat. Whats a good solid final coat option and how do I prep for it?
[pertaining to the 80% that is already painted with some layers of unknown paint, but is in good shape...
Do I just do this whole process to the rusted parts maintly, but sand a few inches into the old paint and just feather everything I do into these couple inches to make the transition...
OR do I just like, clean the old 80% of the keel real good and sand it with 80 grit and start at #4 by goign into/over the old (unknown) paint with the totalprotect epoxy primer and keep covering the whole keel like that from then on? ]
-So is my plan and products good?
-How often do I need to clean, sand, or both in between steps?
-Whats a good simple and solid final bottom paint for the keel of a freshwater boat docked 7 months of year?
-And how do I transition into the old, good, painted areas.... or do I just cover over entire keel starting at the totalprotect epoxy primer step?
Thanks guys (and gals)
The process....
