I'm new to epoxy and I'm lost here. I've tried to figure this out but....
Can someone please give me a specific EPOXY product list to buy if possible? Also any tips on how to go about this or other materials/tools I'll need would be helpful too.
1971 Catalina 22. Owner passed away 5 years ago so I know nothing about the boat but the rest of it seems in pretty good condition all and all.
* Keel is off and about 20% needs repaired...It's rusty on the surface.
* The tabbing is coming apart in the "bilge" areas where the "under" cabin areas meets the hull. (See photos)
I originally thought it was de-laminating (as listed in photo) , but I realize its the tabbing coming undone.
[More details below about all this...2 projects that I will need some sorts of epoxy for.]
1. I have removed my keel on my 1971 Catalina 22 and it was about 15-20% of the surface showing rust, the rest of it looks pretty good. I know I will have to scrape all the rust completely off then I believe I add some sort of Epoxy immediately over it? Can you please recommend exactly what products I will need and also how I should apply it. I will be doing the work in a heated room, 70 degrees or so.
2. I also have issues with the tabbing coming "undone". Looking into the berths and under cabin areas, The tabbing which used to connect the cabin to the hull are basically cracked and peeling off from the hull. The vertical parts of the tabbing seem to be holding mostly well, but a couple inches down on the horizontal parts of the tabbing, which touched the hull, have failed and are basically "peeling off" from the hull. Help!? Do I use the same epoxy as I would for the keel like in my first question? OR do I need a whole other epoxy system? I head I can get tabbing fabric that comes in strips maybe? Please help with step by step specifics and specific products if you can. This will have to be done in a colder environment cause the boats outside and I'm in PA. I can run a heater inside the boat but its still cold out.
THANKS SO MUCH I'm lost and really need to figure this out.
