Merit 22 owners
RussC
Sep 11, 2015
1,735
Merit 22- Oregon lakes
Looks like a good chance I'll get a weather window to test out my shroud and some other upgrades tomorrow. today I put up the mast in my driveway and ran my new jib sail up for a test fit. everything looks good and it certainly fills the fore triangle as it should now :thumbup:. photos are a before and after noting the short jib that came with the boat. it was limp bedsheet anyway and past due for replacement even if it had been the right size.
RussC
Sep 11, 2015
1,735
Glissade came with a very adequate Raymarine depth finder but my search for a decent gps speedometer, at a reasonable cost, had just about pushed me over the edge. I could go on a long rant about what happens to costs as soon as you put the word "sailboat" with it, but I'll resist the urge. I found the (round) unit shown in photo one for under $60.00 and it actually works quite well, as far as accuracy, with resolution to one decimal point. the only problem is it's impossible to see in direct sunlight. I even tried several methods of shading the face but to no avail. I like things simple and cheep, but they do have to also function in the real world! In the end I ripped everything out of the "dash", filled in the holes, and started over again from scratch with this flush mounted Garmin Striker Vivid 7cv. it does everything I need it to do and more, plus it only cost part of one arm and a tiny piece of one leg. a bargain actually, when you realize it's for a boat. :rolleyes:
Nov 6, 2025
1
Merit 25 Muskegon
Is this the only place for Merit owners?
Just bought a 25, anyone have history or info?
john
Apr 8, 2010
2,259
john
A group of about 5 or 10 race one-design in our sailing area. Fast boats and appear to be a lot of fun for the $. Our venue is primarily light air.
I do not know if they have any on-line fleet presence tho.
Here is some web info: https://en.wikipedia.org/wiki/Merit_25
Likes: matthewsx
Nov 23, 2024
7
Merit 22 Port San Luis
Russ, My Merit 22 doesn't have the seams in the liner or any additional brace to the chainplate like shown in your pics. As far as the shrouds, like you, I use a Loos gauge and tighten the uppers to about 15% of breaking strength and the lowers to 10%. 35 and 30 or thereabouts. In heavy wind the leeward lower will be loose but not quite a goose neck noodle but the upper is relatively straight under 20 knts. It looks like your liner might have been compromised at some point for that repair to exist, so you might have to beef up the chainplate linkage in addition to the brace you added. You can cut a window in the liner in the locker to see separation and tab the liner to the hull. The liner was stuck down with a slurry of filled polyester? resin, so you will have to grind away to get to the hull, etc. Good luck, and; hopefully mine is still intact but I may put a port in to check it sometime. On my Merit 22 there is a glassed in circle (to tighten the nuts?) there in the locker that I assume the factory did as it was gelcoated over. My boat was also race heavily in SF Bay and the PO added a bulb to the keel. I have beefed up the compression post, but see no unintended consequences from the added weight. I sail out from a mooring in Port San Luis, and the wind is often over 15 knts. Friday, I double reefed and thought about putting the third in.
RussC
Sep 11, 2015
1,735
Thanks for the input @Hedgeman :thumbup:. I did get one more sail in before the weather turned and I was quite happy with the results of my chainplate improvements. I may still follow your suggestion and put an access port inside the lockers just to see what, if any, corrective measures may have already been taken behind the liner. then further improve as needed. for my test sail I had kept the rig tension the same as it had been so I could determine if the chainplate brace was actually an improvement. it definitely was, as the outers showed almost no slackening and the inners only moderate. When I put in the braces I also fabricated new outer shrouds from 5/32" to replace the 1'8" so I do plan to increase the tension appropriately for next seasons sailing. also made up a new upper backstay from 5/32". better safe than sorry.
keep the Shiny side up
Nov 23, 2024
7
Russ, that is a great upgrade which I also did. I think every Merit 22 should have 5/32" shrouds and forestay. I also replaced the mast tangs with beefier ones from Dwyer and used toggles and staloks instead of nicopress thimbles.
Likes: RussC
RussC
Sep 11, 2015
1,735
Agreed. being a masthead rig I felt the backstay should be considered for upgrade before the forestay however. It would be interesting to know the actual numbers the various lines see wile under sail.
BTW: I looked at the Sta-Lok system and those look very interesting. if I hadn't already made up all new standing rigging I might look into that. I've always been happy with using nicopress sleeves but the sta-lok is a very clean looking solution.
RussC
Sep 11, 2015
1,735
One more winter project in the books. I want to have the option to fly my A sail (stolen from my Mac 25) next summer so I created this shorty bow sprit. tack line will go through the standing block back to the cockpit and I've already installed a double block to replace the single at the masthead for the extra halyard.
is summer here yet?
7
Your sprit looks nice. I have a bow roller on my Merit and I keep the boat on a mooring, so your design wouldn't be good for me. I use a symmetric spinnaker when the conditions warrent, and energy and time are enough. I had a pretty nylon gennaker on my previous Cal 30 that worked great reaching and having only 3 hanks I'd often fly it free especially with double headsails.
RussC
Sep 11, 2015
1,735
Thanks! I single hand 90% of the time so a symmetrical just has too much hassle vs benefit for my lake sailing. It's actually pretty rare to benefit from any spinnaker where I sail as my normal sailing lake has very consistent winds above what I might use the spin in. I might have flown one once or twice all last season but hey... it's winter and I needed a project. that sail it is pretty however :biggrin:.
Your sprit looks great. I like the setup.
I like you color choices. In light winds it was a lot of fun solo sailing.
Likes: RussC
RussC
Sep 11, 2015
1,735
ah yes. your old Montgomery (15?). I'll bet you've missed it a time or two these past couple years eh. :). photo looks a lot like Howard Prairie.
I did sail in Howard Prairie once. I did several of the Cascade Lakes and Lake Billy Chinook. In the valley, I raced on Fern Ridge Reservoir and played/fished Green Peter and Foster. There are so many fun sites. It was a joy to trailer to them, camp out on the boat, and play. Then I got the bug to explore the Salish Sea. I needed a bigger boat. It was sad to say goodbye. It went to a good home. And now I have a boat that can take me to remote waters and return safely to port.
This time I was on Detroit Reservoir, about an hour out of Salem.
