Hello,
New to Outboards and don't want to do something dumb. This motor was said to still run good. But hasn't been run for 5 years. What are the first steps and what not to do? 1973 (ish) Mercury 4hp outboard. Came with my 1971 Catalina 22.
I know I need to get good gas...
1. But do I have to drain any old gas inside?
2. Think mix is supposed to be 50:1.... what kind oil do I buy?
3. What kind of gas? Ethanol free? premium or anything from the gas station?
I have a barrel I can fill with water to run it in.
4. Any risk to damage it...should I test to see if its not "seized"..
5. I see lot people taking spark plug off and spraying some kind oil into it. Necessary? If so what kind oil?
6. Should I loosen the bottom "gear" oil nut to see if the oil is black/creamy/clear/ or even empty?
7. its definitely a 2 cylinder, right?
Any other info greatly appreciated. I basically know nothing so clear and specific steps and products would be great!!!
can come from the hose. Also make sure the gas can is clean and does not have any debis.
