I’ve noticed a small leak on the inside of a portlight (pictured), and can’t identify the exact source. It seems the PO put some silicone on the seam of the bedding compound on the exterior (pictured), which is failing likely due to torsion on the hull while under sail. It’s a very small leak, but I’d like to seal it. Can I rectify this by removing the failing silicone and sealing the seam of the bedding compound with something more appropriate?
I’m sure rebedding the entire portlight would probably be the most thorough method, but due to the fact that this is a boat, and the simplest projects have a tendency to complicate exponentially, I’d prefer to keep this as simple and tidy as possible
