I recently purchased a Hunter 23 and have identified essential repairs, such as a window leak, for instance. The largest repair seems to be the keel, which I believe is cast iron. It has some decent corrosion and should be addressed, even if I can't wait for the first sail.
I have been doing a lot of research on the best way to tackle this keel. Remove all corrosion to a clean, shiny metal, and apply layers of epoxy, and then some fairing/sanding before applying Interlux 2000 in a couple of layers. Is this the right process?
Is it necessary to do this before the first sail, as it was sailed about 7 months ago?
