Yanmar 3GM30F: Wiring Harness & Aftermarket Panel
Aug 7, 2021
142
O'day 28 Casco Bay
I have DOM 1993 Yanmar 3GM30F in my boat and the engine runs fine with the exception of the ubiquitous and occasional "click" starting problem. However, a few weeks ago, I could not get it started (the solenoid is extremely difficult to access) and have decided to tackle this matter during the winter. In the interim, I did clean the engine ground, the hot side of the solenoid and any other connections that were accessible.
My winter work plan is as follows:
1. Improve accessibility by creating a removable panel in the port side engine compartment bulkhead.
2. Replace the starter solenoid. This was a repower, and the one currently installed looks to be for a right-side mounted starter. The ground tab is inboard against the block and virtually impossible to get at.
3. Replace the wiring harness and panel. Both are original and the latter was a pretty ratty install. it is not recessed and I've bent the key on more than one occasion. Also the tachometer only works sporadically.
My question for the group is regarding the panel. Has anyone purchased an aftermarket one from AC DC marine in California? They seem to be very good to work with and will modify one of their standard panels to meet my needs. I am concerned because one of the things I've learned is that the resistance provide by the incandescent "charge" bulb on the panel is related to field excitation on the alternator. Does anyone know any more about this? The new panel will obviously not have any incandescent bulbs.
Nov 6, 2006
10,152
No comment on the alternator field and regulator.... just reference, this is a picture of the OEM solenoid just below the air filter housing.
Aug 7, 2021
142
O'day 28 Casco Bay
Thanks for the prompt reply. Mine is the similar except as mentioned, the terminal for the white wire from the starter button is on the opposite side facing the block, and there is no way for me to get a screwdriver in there. Now it could be that I can just remove the starter and rotate the solenoid 180 degrees. This coming week I'll consult with some Yanmar guys I know.
Jan 4, 2006
7,444
I understand your need to replace the ratty panel but the one thing I can't agree with is :
From what you describe with your problm with the starter motor being reluctant to start cranking when you push the button, this is the simplest and most inexpensive thing you could do for a 100% solution to the problem :
Now you only need to pass 0.69A through the whonky harness as opposed to around 18A to the starter motor.
Aug 7, 2021
142
O'day 28 Casco Bay
Thank you Ralph for your reply. Yes, I've read many posts articles etc. regarding changing the starting circuit, and largely agree with you. My problem is primarily one of access and real estate. Putting a 3GM30F in an O'day 28 is just like the proverbial 10 pounds of excrement in a 5 pound bag. A 2GM20F would've been sufficient, but it's a little late now. I may PM you regarding your layout. Thanks much.
Nov 6, 2006
10,152
The question is whether the LED will allow enough current to activate (excite) the field. My guess is no, but I really don't know. Try calling the panel guys to see how they deal with that.. They may simply use one incandescent to accomplish that task or they may use a resistor...They've probably dealt with that before.. Good luck!
Likes: Charles Erwin
Jan 30, 2012
1,150
Apart from alternator lamp excitement (listen to Kloudie) have a look at the motor connectors. Your experience suggests an intermittent electrical fault. As to these connectors there are two - just above the shift cable arm at the rear of the motor, left side looking forward. Disconnect and spray with your favorite penetrant - WD 40, whatever. Pay attention to the male pins and make them semi-clean with a small wire brush. With any intermittent electrical event - make connections very spiffy first. And particularly so when the circuit involves push-on electrical connectors.
Aug 7, 2021
142
O'day 28 Casco Bay
Agreed Charles. The symptoms are similar to a number of posts on various forums. When the engine or compartment is cold, there is no problem starting. Once the engine is warm and the ambient temperature appreciably changes, current from the push button to solenoid is insufficient to close the circuit and engage it. I've done some additional research and I misread the description of how that works. It's related to the "T" shaped plug on the back of the alternator.
The L terminal (Blue/Black) goes to the charge light; L=light
The R terminal (Red/Black) goes to the load side of the Key switch. R=regulation
The L provides the initial field voltage (via the charge light) when the alternator first spins up. Once the alternator becomes self exciting, no further current flows via the charge light thus it is extinguished. Thus, it doesn't matter if it is an incandescent bulb or an LED.
Since my last post, I've purchased a plunger-type remote start switch, hooked it up and the engine starts and charges without issue. This again points to the harness as the root of the problem. Given the silver paint on it, I'd say it's original (30+ years old).
My winter plan is to change it with an OEM replacement. I cannot confirm but have to believe that any new OEM harness is manufactured using tinned wire, given that it is an ABYC requirement.
The connection to the panel is another matter. The engine harness has Deutch connectors, as does the extension harness (which is about 3 feet too long!). Then there is an adapter harness to connect it to an older style "B" panel with round connectors. I am leaning toward an aftermarket panel which would be connected to the engine harness via a custom made extension harness that I will make myself.
Keep you posted.
