I have DOM 1993 Yanmar 3GM30F in my boat and the engine runs fine with the exception of the ubiquitous and occasional "click" starting problem. However, a few weeks ago, I could not get it started (the solenoid is extremely difficult to access) and have decided to tackle this matter during the winter. In the interim, I did clean the engine ground, the hot side of the solenoid and any other connections that were accessible.
My winter work plan is as follows:
1. Improve accessibility by creating a removable panel in the port side engine compartment bulkhead.
2. Replace the starter solenoid. This was a repower, and the one currently installed looks to be for a right-side mounted starter. The ground tab is inboard against the block and virtually impossible to get at.
3. Replace the wiring harness and panel. Both are original and the latter was a pretty ratty install. it is not recessed and I've bent the key on more than one occasion. Also the tachometer only works sporadically.
My question for the group is regarding the panel. Has anyone purchased an aftermarket one from AC DC marine in California? They seem to be very good to work with and will modify one of their standard panels to meet my needs. I am concerned because one of the things I've learned is that the resistance provide by the incandescent "charge" bulb on the panel is related to field excitation on the alternator. Does anyone know any more about this? The new panel will obviously not have any incandescent bulbs.
