Do I need Bottom paint?
Jul 12, 2023
7
Catalina 22 Kentucky Lake
I have a 1987 C-22 that has always been kept on the trailer or on a lift its entire life. The boat is a freshwater cruiser, never in salt water. Next season I have the opportunity to leave in a slip at one of my local freshwater lakes. I will only leave it for 3 - 6 months not the whole year. Would it be advisable to apply barrier paint?
Thanks,
Likes: Gene Neill
Aug 15, 2022
160
Catalina 22 14790 Redwood City, CA
Personally I wouldn't. Might not hurt to dive it a couple times with a soft brush but if its not in salt water I wouldn't spend the time/money for barrier coat or suffer the performance loss.
Likes: Gene Neill
Sep 24, 2018
3,489
Catalina 30 MKIII Chicago
Stuff will grow on it within a few weeks. I wasnt able to tack when my bottom was dirty. Once I applied some fresh VC17, I had no issues tacking.
You will end up with a dark colored stain at the minimum. Some people acid wash, others use bottom paint
Likes: JBP-PA
Since the osmotic gradient between fresh water and hull laminate is greater than between salt water and laminate I think the need for a barrier coat in fresh water would be greater than for salt water.
But for a short amount of time the risk of getting blisters is low. There should be intact gel coat under whatever bottom paint was/is used.
The photo is named "bottom job." What was done?
I agree an anti-fouling paint should be used with or without a barrier coat. The anti-fouling paint will offer no protection from water intrusion into the laminate.
Jun 21, 2004
2,943
Beneteau 343 Slidell, LA
Just sand LIGHTLY (80 grit) to roughen surface & apply ablative anti fouling paint. No need for a barrier coat because you’re only going to be in water for 3 - 6 months; the hull will have 6 - 9 months annually to dry. If you don’t apply antifouling there will be ample amounts of tenacious growth that will require removal when you haul out.
Sep 30, 2013
3,602
Are we definitely talking about barrier paint, or do you mean anti fouling paint?
I don't think I would bother with barrier paint for just 3-6 months at a stretch. Anti fouling ... maybe. Every body of water seems to foster different organisms at a different rate, so it's worth talking to other boat owners at your own marina. Can you/will you snorkel around and give it a scrubbing every few days? How attached are you to that perfect gleaming white bottom? Et cetera ...
Likes: JBP-PA
JBP-PA
Apr 29, 2022
638
Jeanneau Tonic 23 Erie, PA
Yep, if it's in the water for 3-6 months, you'll want some anti-foul paint. It'll help keep the growth down. A barrier coat is unnecessary if you dry out for 6 months a year, but wouldn't hurt. Most any anti-foul will do well in fresh water.
I’ll add another vote for not bothering with an epoxy barrier coat but yes for antifouling bottom paint. I don’t think the exposure to osmosis and blistering will be high enough for that to be a concern, but you’ll almost certainly have slime buildup slowing the boat down very quickly without paint.
Likes: JBP-PA
Sep 24, 2018
3,489
My last boat was in the water for no more than six months per season and in heated storage in the winter. Previous owner barrier coated it. I applied VC17 as needed. It ended up with thousands of tiny blisters. It was in Southern Lake Michigan
ShawnL
Jul 29, 2020
165
Catalina 22 3603 Calumet Mi
Another member of the choir here.
I keep my boat on a mooring in a fairly small (and stagnant) bay off of Lake Superior all summer and use an ablative bottom paint. No idea if I have a barrier coat or not. I pressure wash the boat when I pull it in the fall, then do it again 2x in the spring with a scrub from a coarse brush attached to a painter's pole in-between. Then re-coat. A gallon of paint lasts me 2 seasons. At some point I'll probably have to sand it all off and re-do something, but it's been working for me so far.
Lake Superior is cold, but diving on the bottom mid-season does still show some slime. No growth to speak of, but I suppose if I was a racer I'd probably try to scrub the hull. In fresh water, you're not going to get any anything more than slimy growth (I think), but I feel better knowing I have an ablative paint (Jamestown Distributors) on both the hull and rudder. I just slap it on with a roller and a paint-tray and do the best I can around the trailer bunks and it seems to work for me.
Likes: JBP-PA
Sep 24, 2018
3,489
We get tons of zebra mussels. They seem to like metal the most but that's likely because it doesnt have any bottom paint
Likes: JBP-PA
Jun 1, 2004
8,219
Ablative bottom paint, no barrier coat ditto. Do a quick research on the difference between the ablative type (aka sloughing) and the hard shell type (I used to call it "modified epoxy, but there are more variations now so always look for "ablative" in the description).
For those who leave their boats in the water year round, the hardshell type is more popular and longer lasting, it works by slowly emitting anti fouling agents...but...exposure to air and sun leaches those agents out of the paint with increased rapidity. An ablative paint works by water moving across the hull surface "sloughing" off microscopic layers of paint that take the nasties along for a death ride. The paint is not affected by the elements the way hard shell paint is, making it the choice of sailors who trailer or haul their boats seasonally.
Applying bottom paint is most likely the easiest DYI project a boatowner can have. Just one pre caution, as mentioned elsewhere, if your bottom is fouled when you haul out, attack it immediately because it's way more difficult once the slime drys out. I leave my boat in the water year round, using a reliable dive service to wipe the bottom down monthly. I can usually go 5 years or more before needing to repaint over the old hard shell paint. I always have the diver clean the bottom a day or two before haul out to make the subsequent wash faster and more effective... sometimes I've even been able to avoid the $150 yard fee for power wash with this strategy. Ablative paints are typically renewed at the beginning of the sailing season, right over the top of whatever was left from the previous one. I've never had a boat situation where I used ablative paint, always the hard shell, or none at all, so other's advice might be more relavant than mine. In any case... good luck, have fun.
JBP-PA
Apr 29, 2022
638
It had a barrier coat, was dried out for half the year, and still had blisters? Did you ever figure out why?
Sep 24, 2018
3,489
Nope. I sold the boat beforehand. I love that boat. I still miss it but I'll be damned if I'm going to grind and fair all of that
