Furling line Q’s
Aug 17, 2013
1,075
Pearson P30 202 Ottawa/Gatineau
Hello all
Still trying to get my boat to a comfortable place to use.
My question is what hardware do you all use to secure the furling line at the cockpit?
I am also wondering if port or starboard makes a big difference in using it? ( probably not)
I am trying to better the exit angle from
The drum as the line is in the way of the anchor chain and rode.
I will take pictures next time at the boat, the pictures I have are before the add of of the anchor roller
Oct 10, 2009
1,057
Catalina 27 3657 Lake Monroe
I think the line exiting the drum perpendicular is best. Port or starboard depends on which side of the sail your UV cover is on. I kind of like an old fashioned horn cleat, so that I can use a half wrap to control unfurling.
Jan 7, 2011
5,793
Oday 322 East Chicago, IN
My furling line originally ran down the port side deck, through some blocks mounted on the stanchions. It terminated at a small cleat on the side deck next to the helm. It worked ok, but I found it hard to pull in the furling line while leaned over the side deck.
i had an open rope clutch on the port side cabin top, so I rerouted my furling line to the port side cabin top, moved one of the blocks so the line could run fair back to the clutch.
I find this to be a great “upgrade”. I can use the clutch to stop the furling line from running when I want to reef the jib, and pulling the furling line, even in 20 knot winds is so much easier when I can just pull it straight back and not lean over.
Likes: Timm R Oday25
colemj
Jul 13, 2004
766
It doesn't matter which side the furling line is on, but it does matter which direction the furler turns. The side of your sail with the UV cover determines which direction the furler needs to turn, and once you pick a side for the furler line, you feed it either across the front of the drum or the back of the drum, depending on which way you need it to turn.
I prefer to pull toward my dominant side, so like the line on the starboard side. But it doesn't make that much difference, and we have two furling sails with a line down each side anyway.
The furling line needs to enter the drum perpendicular. You might need to lift the furler a bit with a link plate if it is interfering with the anchor.
Cleat or clutch works for securing the line. It greatly helps if you lead it near a winch, as that can be used for a snubber for better controlling the unfurling of the sail. A clutch is way more convenient than a cleat.
Mark
Likes: LLoyd B
Ward H
Nov 7, 2011
3,807
We enter our boat on the starboard side so I try to keep the starboard side deck as clear as possible. For that reason I chose to run the furler line along the port side. I also chose "outside" stanchion blocks. I have a ratchet block on the pushpit stanchion to turn the line back forward a bit to a horn cleat. The ratchet function helps to control the line when unfurling the sail.
Sep 24, 2018
3,751
Catalina 30 MKIII Chicago
You should be able to put it on either side so long as it's wrapped around the drum in the correct direction. My last boat had a standard cleat. My current one has a cam cleat
Likes: fred1diver
You mentioned that the line is in the way of the chain and rode.
This is what I used on my H26 to control the line.
They allow the line to live "outboard" of the deck and cockpit. They come in many styles...
You should be able to exit the drum and take the line perpendicular to the gunnal and to a turning block and then through fairleads to the cockpit and put a cam cleat on the last stanchion.
--------Bow Pulpit ----------------------- Aft-Stanchion
Do a search for "Stanchion Mounted Fairleads" and you will get many choices.
Jul 5, 2011
754
Oday 28 Madison, CT
I start with a block assembly, mounted on the bow pulpit. That starts the furling line off in the right direction guiding it down to three turning blocks on the stantion bases, then back to a small cleat a couple feet past the port winch.
Likes: fred1diver
Feb 22, 2015
15
Catalina 30 Redondo Beach
I orginally had fairlead blocks. When the rollers wore out, I replaced them. But the lines occasionally got in the way as they were threaded on the inside. A few years ago I replaced them with dyneema loops. I wrapped the loops around a stanchion forming two ears through which I threaded the furling line. Works perfectly. The lines are out of my way being threaded on the outside. Bonus: much less expensive. Simple to construct.
Likes: AaronD
Aug 17, 2013
1,075
Do you have a picture by any chance?
Feb 22, 2015
15
About same, maybe a bit better. No complaints from crew. The black line is weathered braided dacron, compareably rough. Dyneema slick enough as there are no sharp turns. I did use a block off the drum to keep line from crossing the anchor hatch.
The loops are out of 1/4" dyneema for no other reason than I had that on board and find smaller stuff a pain to splice. Don't remember loop size, but not critical.
No noticeable chafe nor wear in 10 years. Unsurpising as very little stress on the loops.
While the old hardware occasionally reached out to scratch me the loops are better behaved. Wish my cat was as considerate.
Likes: fred1diver
Aug 17, 2013
1,075
Thank you all, I added a spin lock stanchion roller, still need to do final adjustments.
now the follow up question, how long do you think the furling line is? I am asking because I want to replace it for longer for easier control from the cockpit. The boat is a 30 foot Pearson p30
At the moment the furling line goes to the aft stanchion with the sail deployed, which is at the e front of the cockpit, I would like to be able to control it from the helm at the rear of the cockpit.
I am thinking about getting a 75 ft long rope and cut it if necessary (probably will be) or should I save money and get 60’ instead?
what would be the minimal diameter you would all recommend?
thank you
May 1, 2011
5,193
Pearson 37 Lusby MD
Fred, my furling line is 1/4 in and does fine. I estimate that I have 45' of furling line, so 60' on your boat should be more than enough.
Likes: fred1diver
On my 35’ boat the furling line comes into the forward half of the cockpit. There I can manage the furler while controlling the jib sheets. There would not be the necessary room if it was behind the helm. The AP is in control of the helm while I deploy the jib/genoa using the jib sheets and the furler line. I have a simple cleat to secure the furler line should I be setting a reef in the foresail.
My furler line is 7 mm Double Braid Polyester (70' / 21.3 m)
