For those of you who have switched between polyester and dyneema halyards on the same boat, what kind of performance increase/decrease did you see (measured in % of speed or boat speed in knots at a certain windspeed)? I just replaced my halyards recently and spent a bunch of money on dyneema halyards. I'm considering perhaps just getting polyester halyards next time. But I'd love to hear feedback from those who have tried both (preferably on the same boat).
And some sail-theory:
The elasticity difference between polyester and dyneema seems to come into play when sailing upwind and the sail is dynamically loaded (gusts). If the loads were completely static, there would not be a benefit from low stretch lines. And it matter mores when sailing upwind because of how halyard tension affects draft. To the extent you would want halyard tension to change in a puff, you would probably want to increase halyard tension in order to maintain draft amount and position. A stretchy halyard does the opposite, potentially causing the draft to increase, move aft, and increase heel. But how pronounced is this effect? It seems like low stretch halyard is an expensive solution to a niche problem.
