Possible Transmission Oil Leak at Shift Lever – Kanzaki KM2P
Jun 14, 2025
188
Hunter 1981 30 Chesapeake
Rick Neary, East Coast Marine Transmissions. He was the head mechanic for Mack-Boring the East Coast Yanmar distributor until M-B got out of the service business.
Thank you. I will send an email to them with an inquiry on this situation.
Jun 14, 2025
188
Thank you for the contact information.
According to them I need to bump the transmission back into alignment, get the three bolts through Yanmar, and reinstall them. He mentioned it would be a five minute job once I have the parts from the Yanmar dealer.
Now I've got to locate a Yanmar dealer near me.
Jan 4, 2006
7,769
Certainly sounds easy enough and I hope that's all there is to it.
If you'll read or TRY to read this extract from my Yanmar 2002 shop manual, you'll see why I didn't bother to pull the pages to send to you way back in the beginning. Maybe if I had the xmission in front of me and read the description a few thousand times over, it may have seeped in through osmosis, but I gave up early as it just did not make sense.
188
Thank you. I will review this.
At the moment, I'm searching for the part numbers of the three bolts as well as the shims I need. I'm not sure where to get it. My transmission is the Kanzaki KM2P with a 2.62 gear ratio.
Edit: Got the part numbers from the catalog.
Shim Set:
177088-06380
Center Bolt:
177088-06360
Collar Bolts (Need 2):
26013-080252
I guess I'll just order them up and see how they fit. Praying the threads catch and everything works out!
Try Niemiec Marinę in CT.
Sep 26, 2008
792
Hunter 340 0 Wickford, RI
I took some photos of my Kanzaki KH2P Transmission shift assembly lever area you are asking about. I have no leaks of fluids in or around the area and see no signs of a weep hole you ask about as well. I know its not the same transmission as yours, mine is for a Yanmar 3GM30F but is shows how the assembly is attached. Sometimes it helps to see a picture as well as a reference point. Not the easiest of places to get a good photo, but you’ll see the matchup.IMG_1712.jpegIMG_1700.jpegIMG_1697.jpegIMG_1695.jpeg
Jun 14, 2025
188
Hey everyone — it’s a great day out here, and I just wanted to share a small win. I’ve officially solved the transmission mystery!
I got in touch with a technician from East Coast Transmission, confirmed the missing parts with Yanmar, and ordered everything I needed through a Yanmar parts dealer. The whole order — just a couple of bolts and shims — ran me about $80 including freight, and I’ve gotta say: they fit like a glove.
Best part? No more transmission oil leak. That’s one big item off the checklist. Still plenty more to go, but this one feels really good to knock out.
Appreciate all the help and advice from everyone here — more updates soon.
Glad that Rick was able to help you. Be sure to send business his way. He deserves it!
Nov 24, 2009
6
Pearson 36-1 Enkhuizen, NL
I had a similar oil leak from the Kanzaki KM2P. The oil seal just inside the shift lever was leaking. While I had removed the shift lever, I replaced the oil seal and the "O" ring also shown in the illustration. The missing bolt you described is a "stop bolt" with shims. In a Yanmar service manual, there are details about measuring how many shims to use. It's not a difficult job depending on your access to the back of the engine. The seal and "O" ring weren't expensive either. Parts 14 and 3 are what you need.
6
Yes, the position of the shift lever on a KM2P is critical. I had created my own problem of the transmission not going into forward easily, seems the transmission didn't want to engage until I revved the engine. Then I learned that the forward and reverse positions of the shift lever should be 45° from neutral, but 45° is difficult to judge or measure when one is standing on one's head and the Yanmar is not level fore and aft to begin with. I resolved the issue by pushing the shift lever to reverse and then loosening the shift lever and pulling it back a few millimeters. Now the transmission engages in both directions correctly...
