I just replaced two group 34 AGM batteries with one LFP. I saved about 20 pounds and have about 6 times the usable capacity.
The install isn't finished yet. I need to buy some hardware and strap the battery down. I also need to add a DC to DC charger.
I have reprogrammed the charge and float settings on my Pronautic P1230 charger. I set it at 14.2 charge and 13.2 float. I verified that it stopped charging when the battery was full.
The alternator is presently connected to both the house and start battery though an isolator. With the charger on and the engine running the charge current was at about 45 amps. I ran the engine for about 5 minutes at cruise rpm and the alternator barely got warm. The charger is only connected to the house battery. It pumped out 30 anps for hours, it got very warm.
I will probably add a DC to DC charger. It with draw from the starter battery and feed the house battery while the engine is running. I am also considering adding a trickle charger for the start battery.
I also have a Victron Smart Shunt to help keep an eye on things.
