Up grade the charger and you should get 6-8 years from the batteries.But at this point, I think I am going the easy route and replacing my lead acid batteries in kind and be good for another 4-5 years.
Thanks Dave….it is certainly an old charger. Doesn’t owe me anything.Up grade the charger and you should get 6-8 years from the batteries.![]()
So how would I size a charger for future use and a change to LFP? I would probably use a 280ah battery or 2) 100ah batteries plus my start battery (70 ah LA).Up grade the charger and you should get 6-8 years from the batteries.![]()
There is a maximum current that you should not exceed which for FLA is 0.2C or 20% of your rated Ah capacity or the charge capacity of your BMS for FLA. On my 560Ah that is 200A and on my two 460Ah batteries on my motorhome it is 200A each or 400A total. I charge my 560Ah with 190A and my 920 Ah with up to 170A because that is the most I have been able to install.So how would I size a charger for future use and a change to LFP? I would probably use a 280ah battery or 2) 100ah batteries plus my start battery (70 ah LA).
Is there a guideline or formula for how many amps the charger needs to be for say a total of 270 ah of batteries?
I seem to remember MaineSail had a guideline, but I cannot find it.
LA batteries care about current and voltage, too much voltage or too much current are a problem, likewise too little of either won't do a good job of charging a LA. LFP care less about current and a lot about voltage. They do not like float voltages when fully charged. And over voltage charging will damage them.So how would I size a charger for future use and a change to LFP? I would probably use a 280ah battery or 2) 100ah batteries plus my start battery (70 ah LA).
Here is a link to your charger's manual. Guest 2614A Owner's Manual (Page 11 of 15) | ManualsLibThanks for all of the comments so far. I was at the boat today and got some info on my old battery charger…
Guest 2614. From 2003. I don’t think that this charger will be good for LFP…
View attachment 232402 Specifically says for lead or gel…View attachment 232401
here are the only charging profiles…
View attachment 232399 View attachment 232400
On a positive note, my Renogy battery monitor says it would work with LFP.
Thanks for the comments and suggestions.
It should be noted that none of the ACR's that I am aware of will work with any LFP battery. They combine the two banks when either hit a voltage of over 13.0v. My LFP batteries spend 75% of their life at voltages over 13.0v. The disconnect when the combined voltage drops to 12.75v. My battery is deeply discharged by the time it gets to 12.75v....
If your house and start batteries are connected with an ACR, then the number of batteries that can be charged from the charger doesn't matter, you only need one connection.
Correct, I was referring to using it with LA batteries not mixed chemistry. A DC-DC charger also works well and allows for more control over charging parameters.It should be noted that none of the ACR's that I am aware of will work with any LFP battery. They combine the two banks when either hit a voltage of over 13.0v. My LFP batteries spend 75% of their life at voltages over 13.0v. The disconnect when the combined voltage drops to 12.75v. My battery is deeply discharged by the time it gets to 12.75v.
These voltages are perfect for FLA but with LFP you are basically connecting them in parallel continuously. Much better to use an ArgoFET combiner that only connects them for charging currents and always keeps the two banks separate.
SI-ACR Automatic Charging Relay - 12/24V DC 120A - Blue Sea Systems
Thanks Hayden.Here is a link to your charger's manual. Guest 2614A Owner's Manual (Page 11 of 15) | ManualsLib
On page 11 it shows that your absorption voltage is 14.3v and float is 13.3v. Both of these will work for LFP although I prefer to have a lower absorption of 14.1v to reduce the chance of one of the cells hitting the high voltage limit of 3.65v and going into over voltage protection. Many battery manufacturers recommend a charge voltage of between 14.3v and 14.6v but that means that the BMS will go into protection every charge cycle and I personally do not like that method of balancing.
Even though it would work, I would still install the IP22 30A because your 10A charging max will take a long time to recharge.
Thanks Dave.LA batteries care about current and voltage, too much voltage or too much current are a problem, likewise too little of either won't do a good job of charging a LA. LFP care less about current and a lot about voltage. They do not like float voltages when fully charged. And over voltage charging will damage them.
With a 115a house bank and a 70a start battery, a 20 amp charger would be the minimum. The standard recommendation is 10% of the total capacity. with about 200ah capacity, a 20 amp charger would be necessary, a 30a charger would be better.
30a would also be OK for a 200ah LFP battery bank or even a 100a bank. LFP can easily accept up to 40% of the capacity for charging.The important characteristic is maintaining the voltage profile, not the amperage. A smaller charger, like the 30a will just take a little bit longer to recharge the battery, about 6.5 hours instead of 5 hours to go from 0%SOC to 100% SOC.
DC to DC chargers is a way to handle charging of the LFP bank but I struggle with the low current that it allows. I want to maximize the current I get from my engine so have installed a 250A large frame alternator on my 23-HP diesel and control it with a Zeus regulator so that I can limit the max output to 190A to keep my batteries happy and reduce the current at higher rpm to retain enough power for my prop. As a result, I am able to charge at 180A at 1900rmp and still make 5.4kts without over stressing the engine. That lets me recharge a fully depleted 560Ah bank in a bit more than three hours. In the 27-years I have owned my current boat, I have used 1900rpm for well over 90% of my motoring. I only rarely go above that because I just do not like the sound.Correct, I was referring to using it with LA batteries not mixed chemistry. A DC-DC charger also works well and allows for more control over charging parameters.
Hayden, that works for you, your sailing plans and your interests, however, Greg's plans are considerably more modest than yours, a simple solution will meet his needs.DC to DC chargers is a way to handle charging of the LFP bank but I struggle with the low current that it allows. I want to maximize the current I get from my engine so have installed a 250A large frame alternator on my 23-HP diesel and control it with a Zeus regulator so that I can limit the max output to 190A to keep my batteries happy and reduce the current at higher rpm to retain enough power for my prop. As a result, I am able to charge at 180A at 1900rmp and still make 5.4kts without over stressing the engine. That lets me recharge a fully depleted 560Ah bank in a bit more than three hours. In the 27-years I have owned my current boat, I have used 1900rpm for well over 90% of my motoring. I only rarely go above that because I just do not like the sound.
Both my LFP house and AGM start are charged from the alternator but are kept isolated from each other by an ArgoFET 200-2. Both batteries are very happily charged with the 14.1v absorption / 13.3v float that I have the Zeus set to.
It is ABYC compliant to connect the charger directly to the starter battery (with over current protection), but the cable running from the starter battery to the starter needs to go through a battery switch.What I found is that the 2 channels on the charger are wired to the #1 and #2 post on the battery switch (common I guess). I will reroute the #2 wire to the starter battery directly. The wire to the starter runs to the C post on the switch, so I will pull that and run it to the starter battery directly as well.
thanks. I am planning to add a cutoff switch between the battery and the starter. Good advice.It is ABYC compliant to connect the charger directly to the starter battery (with over current protection), but the cable running from the starter battery to the starter needs to go through a battery switch.
