Are you using this to take water on-board, or to use water from your tank? If from your tank, then you will get 20-25% usable water from the amount you can store. The remaining will be tossed as waste. So for example, if you have a full 100gal tank, then you will get 20-25gal of water out of it. So you in effect have a 20-25gal tank now.
This could be OK if you are just short-sailing and don't need a lot of water between being able to fill the tank again.
Your drawing shows a storage tank, but no clear way to use that water or get it out.
One thought is to plumb the waste discharge back to the water tank. This will give you most of 100gal capacity back. It's not like this is seawater, where the brine levels would quickly escalate to the point of exceeding the system capacity. Every so often, completely empty the tank and refill. It is going to dilute anyway every time you fill the tank, so should be able to get several exchanges before complete empty.
Mark
Mark
