Air Conditioner
47
Catalina 34 Hudson
Hey Gang ..I have a brand new ac on my Catalina 34 and my 2400 gen will not run it. Has anyone ever used one of the portable ac's like zero breeze? Also the have a new one for RVs that is 12v and mounts on the roof...any thoughts?
Sep 24, 2018
3,405
Catalina 30 MKIII Chicago
Zero Breeze units were discussed here a month or two ago. I believe the general conclusion is that they're more appropriate for a tent rather than a boat due to it's low output
Likes: JBP-PA
Johann
Jun 3, 2004
512
Leopard 39 Pensacola
When you say the generator won’t run the AC do you mean it won’t start it? What is the continuous rated output of the generator? You may get by with installing a soft start.
Likes: kloudie1
JBP-PA
Apr 29, 2022
620
Jeanneau Tonic 23 Erie, PA
Yep, zero breeze does not cool very well. I borrowed one and tried it on my 23ft boat and it didn't cool much.
colemj
Jul 13, 2004
617
A 2400W genset should easily run a 16,000 BTU A/C even without a soft start. What size and brand is the new A/C? How is it failing to run off the genset? I'd explore just why it isn't running off the genset before tossing a new A/C for something else.
Mark
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
I know guys had trouble starting that AC with Honda 2000 but added soft start for the startup
Nov 6, 2006
10,093
Make sure the electrical connections are clean and the wire size is adequate for the air conditioner voltage supply.
colemj
Jul 13, 2004
617
You would get more usable help if you answered the questions on what genset, what is its rated continuous output, and what brand and model A/C. Otherwise, we are all just guessing along with you here.
Mark
Nov 6, 2006
10,093
The connections I am thinking of are at the back of the power Inlet socket, at the breaker panel buss, the breaker connections, etc.
