Fitting PYI Flexible Coupling
duck21
Jul 17, 2020
200
Hunter 376 0 Washburn, WI on Lake Superior
Hi all,
I measured and determined a split coupler would fit on my Hunter 376. Today I attempted an install but ran into a bit of an issue -- the coupler fits, but I'm unable to wiggle the bolts in between the shaft coupling and the transmission flange.
I considered removing the shaft coupling, pulling back the shaft, installing to the transmission flange, then reconnecting everything but given the space this would mean that I would not have room to back off and access the packing nut should I have a leak/need to replace the packing (that is, with out having to pull the prop shaft from the shaft coupler, which would be difficult when in the water).
I will try shorter bolts, but I'm not sure that there is enough room even for those (while still leaving enough room to properly thread the nut). There is also not enough room to feed in the bolts from the transmission side.
I'm wondering if others have run into this and if there is a "trick" or procedure that I'm not considering to make this work. Or, maybe I'm just out of luck (but I'm hoping to find a way to make this work).
I've included some pictures for reference, in case that's helpful.
Thanks!
Doug
1,514
Is the white part a damper plate? If so , will it work without it?
It appears that you could shorten the hose by 1" and not suffer any consequences.
duck21
Jul 17, 2020
200
The white part is the flexible coupling I'm trying to add. My original setup did not include it, but they are supposed to run quieter and reduce wear and tear on the Cutlass bearing, as well as reduce chances of damage if the prop is fouled.
I'll have to measure and see how much extra space is available between the hose barba there. I might be able to gain .5+ inches.
Doug
Doug
The split coupling from PYI is heavy duty and a bit longer than split couplers from Buck-Algonquin and other companies. That and the addition of the flexible coupler exceed the space available. This will make it difficult to adjust the stuffing box as you have learned.
To solve the bolt issue, insert the bolt from coupling side with the nuts between the transmission flange and the transmission.
Likes: Blitz
Jan 7, 2011
5,999
Oday 322 East Chicago, IN
I replaced my original stuffing box with a Volvo dripless seal. I did it because I wanted a dry bilge, but in your case, it would provide you with a significant amount of space…
And you would have an added benefit of a nice dry bilge!
Jun 21, 2004
3,210
Beneteau 343 Slidell, LA
I replaced my original stuffing box with a Volvo dripless seal. And you would have an added benefit of a nice dry bilge!
:plus: That picture says it all!
Doug, The Volvo or Radice seal would solve your problem inexpensively, only $140.
with relatively simple installation.
Greg, Just curious if you have a water injection nipple on your setup. My Volvo shaft seal works great! Nice having a dry bilge & no need for stuffing box adjustments; however, I developed a leak where the nipple fits into the FRP shaft log. Just removed the nipple for inspection, in July, when I replaced the 17 year old VOLVO seal. I usually do one wrap of Teflon tape & 4200 that works satisfactorily (when installed dry). Really didnt want to haul out for this, so I removed nipple (yes there is water flow into shaft log from internal cutlass bearing, but not a flood). Retaped nipple & coated with Sea Goin underwater epoxy paste & reinstalled. So far, so good…..no leaks. Haven’t run motor in gear yet, so final test to come. Regret not installing a Radice seal that has nipple incorporated into the seal; no need for nipple into the FRP shaft log.
duck21
Jul 17, 2020
200
I'm liking the Volvo dripless idea. I'm going to order one up and see if it gets here before spring launch! (Otherwise I'll stick with the direct bolt setup for this season and do the swap next year).
Thanks for the advice everyone!
Doug
Jan 7, 2011
5,999
I do not have an injection nipple on my set up. My seal is right next to my thru hull for the engine cooling water, so when I open the thru hull before starting the engine, I give the seal a little squeeze to bleed any air out.
these photos show the progression of my journey…
original shaft & stuffing box. Then new shaft and painted bilge, but old stuffing box, and finally, with Volvo shaft seal.
Hard to find it, but the thru hull handle for the engine and head intakes are down there, so really easy to give the seal a squeeze before heading out.
@BigEasy If the nipple is in the stern tube, how does that release air in the end of the seal? Isn’t the engine side of the seal higher than where it attaches to the stern tube? I thought about trying to drill a hole in the rubber part of the Volvo seal and stick a nipple in there, but don’t really want to create a problem I don’t need to fix at this point.
Mar 7, 2022
15
Beneteau 311 Dallas Corinthian Yacht Club
I went through my own saga of a broken injection nipple the first half of this year (Thanks @BigEasy ). I have a non-Beneteau replacement that seems to be working well, and replaced the Volvo seal while we were at it (though next time I'm definitely looking at the Radice).
However, the dripless seal isn't especially dripless and I'm wondering what other's experience is? It definitely drips at forward/reverse idle, but the engine is a bit jumpy at these RPMs and so there's a fair amount of driveshaft movement. (Working on that.) But this is a video at ~2500 RPM and you can see some water is thrown. It doesn't leak at all at rest. (Mud dauber carcass at no extra charge.)
Do others have this behavior?
2500 RPM.mp4
Jun 21, 2004
3,210
Greg,
See @Shorinsean video for the location of the nipple & shaft log location; my set up is exactly as depicted in his video.
It's debatable, in my opinion, if a nipple is needed at all. Afterall, there is water that enters the shaft log & Volvo seal by way of the internal shaft tube & cutlass bearing. The only time that I vent or burp the seal is immediately after launch following a haulout. I fail to see how air would be introduced into the system, except when the boat is out of the water. I don't think it's a good idea to drill into the Volvo seal.
3,210
the dripless seal isn't especially dripless and I'm wondering what other's experience is?. It doesn't leak at all at rest. Do others have this behavior?
Definitely appears to be a problem. I changed my 17 year old Volvo seal last year just because it was overdue for replacement.. The old seal didn't leak a drop nor does the new seal leak...it is perfectly dry. Your video shows a high degree of oscillation of the shaft within the seal. Could be an alignment problem, engine mount problem, or a bent shaft.:(
Apr 8, 2010
2,247
That rhythmic movement is something I have not seen before. :confused:
Some years ago, before I changed out the worn-out mounts on our former diesel, there was enough shake to cause some water to spray out. This was on a PSS seal. That particular type of (carbon face) seal does not like shaking or vibration.
Same PSS seal on our newer Betamarine seems to be water tight, although starting up after the boat sits for several months thru the middle of winter does show some leaks from gunk that grew on the face during the downtime. Cure for that is to insert a cloth rag and wipe the two surfaces - motor not running of course.
The Volvo seal is totally different in design, but I would guess that it also wants the engine to 'stay put' on good quality mounts and to be aligned properly.
Keep us in the loop as you find the cure...
:waycool:
The dripping is likely due to an alignment problem which may be caused by weak engine mounts. If this is an older seal, the age may also be a factor. Had a similar issue with a PYI Shaft Seal, Engine alignment was poor and when motoring the seal would break and water sprayed in. No leaks when the engine wasn't running. The cause was poor alignment.
Mar 7, 2022
15
Root cause analysis would seem to indicate engine mounts, hopefully, even though the Yanmar 2GM only has about 300 hours on it over the 24 years the boat's been out of the factory. And a visual inspection of the mounts don't show any obvious failure.
  • We replaced the shaft seal with a new one, so it shouldn't be that.
  • The engine "bouncing problem" was noticeable before the replacement, so misalignment of the shaft attachment is unlikely
  • My contractor examined the shaft and prop during the replacement and didn't notice anything. Plus, as a vessel that's designed to be beached, the prop shaft is really well protected
Am I missing anything? A quick search for Yanmar mounts finds a price point of around $400/4.
Ellebogen makes mounts for Yanmar that are about half the Yanmar price. I had them installed on my boat earlier this yer.
The only problem with Ellebogen is the tariff as they are made in Europe. In the past goods valued at less than $800 passed customs with no tariff, that appears to be no longer the case. Until it is sorted out, shippers like DHL and sovereign post offices are not shipping small items to the US.
Ellebogen plans to be at the Annapolis Boatshow this October. Perhaps they will be opening a distribution center in the US to get around this problem with the shippers.
Mar 7, 2022
15
Thanks, Dave, I'll make a note. Yay, my first direct encounter with tariff fallout :mad:.
Apr 8, 2010
2,247
Keep in mind that rubber compounds are intrinsically NOT stable. The material hardens over time whether in use or not. The old (and that number of years is indeed 'old') mounts are way beyond their change-out date.
Of course that's an opinion, found on the internet, and worth about .02 on some days...)
Jun 21, 2004
3,210
I recently changed my original Yanmar mounts in January at 19 years Age. Total PIA because of Beneteau’s configuration for accessing the backing nuts. Took approximately 30 man hours; no way/ no how could I have done it without an extra pair of hands. When I checked Yanmar prices for 4 new mounts, total cost was approximately $1200 for OEM Yanmar parts only. As @dlochner advised, Ellebogen mounts were approximately $500 for a new set, including tax & shipping. Mounts appear to be well made, dimensions are same as Yanmar, & reviews are positive. Took approximately two weeks to receive. Word of caution, regardless of sourcing, check the outboard surface on each mount for shore hardness rating that is stamped on the rubber surface. On my Yanmar 3YM30, mounts had a rating of 100# for the two forward mounts & 75# for the two aft mounts. if/when you decide to replace them, PM me & I will try to provide more info. BTW, Yanmar advises replacement every 5 years; ain’t going to happen!
Mar 7, 2022
15
Looked at a few Yanmar engine mount replacement videos; after watching I'm convinced that's the problem. A couple of people used the Oceanic Innovations mount, which are priced at $540 for 2GM and 3GM motors and based in the US. Has anyone else used them?
One nice trick a fellow did in a video was to superglue the bottom washers to the mounting nuts so he could just slide the box wrench with the nut on it into the underside of the supports without trying to squeeze a hand in there.
