Hi all,
I measured and determined a split coupler would fit on my Hunter 376. Today I attempted an install but ran into a bit of an issue -- the coupler fits, but I'm unable to wiggle the bolts in between the shaft coupling and the transmission flange.
I considered removing the shaft coupling, pulling back the shaft, installing to the transmission flange, then reconnecting everything but given the space this would mean that I would not have room to back off and access the packing nut should I have a leak/need to replace the packing (that is, with out having to pull the prop shaft from the shaft coupler, which would be difficult when in the water).
I will try shorter bolts, but I'm not sure that there is enough room even for those (while still leaving enough room to properly thread the nut). There is also not enough room to feed in the bolts from the transmission side.
I'm wondering if others have run into this and if there is a "trick" or procedure that I'm not considering to make this work. Or, maybe I'm just out of luck (but I'm hoping to find a way to make this work).
I've included some pictures for reference, in case that's helpful.
Thanks!
Doug
Thanks!
Doug
