Sunken Treasure
Sep 27, 2008
153
Hunter 33 salem
I am curious..
How deep is the water where this boat is down?
Do you intend to bring her up on your own?
Are you thinking barrels/air bags?
Depending on the reason it sunk, you may need big-ass pump to keep her
floating before it can be hauled...
colemj
Jul 13, 2004
575
That thing has been down for ~1.5yrs. It is fish habitat now, not human.
Mark
Sep 27, 2008
153
Hunter 33 salem
Food for thought....
I like the ping-pong ball idea... but it could cost a bit.
Lift bags are way to go.......... a few of these....and she's on the surface.
I am thinking the boat weighs 25K lbs and has some buoyancy so its going to be something less
Jun 2, 2004
3,532
We used waterbed mattresses before they had the baffles. Dove down unfolded them in the cabin hooked up the hose filled it with air and up to the top it would go.
All about pushing enough water out of the boat so that there is less water in the boat than the hull displaces. Easier to get in and to keep it in than ping pong balls.
Can you even still get waterbed mattresses?
Sep 27, 2008
153
Hunter 33 salem
depth. is a big factor with "inflated things".
Every 30ish feet, is an atmosphere so an inflated item will be 1/2 is size 30's down and even smaller the deeper you go.
So how far down do you believe this to be? Can you see it?
lift bags have vents so.. ya fill it at depth and as it rises, it lets out the expanding air......
Grumps
Mar 4, 2021
71
Macgregor 25 Trailer
I am curious..
It’s in about 18 feet of water now that the lake is up. I have a professional that’s going to raise her up if I end up with it.
Grumps
Mar 4, 2021
71
I am curious..
Mark
Yep, but I get to keep what I catch
Sep 27, 2008
153
Hunter 33 salem
by 18' you mean, mast sticking up ? or 18' to the top of the mast?
either way that should be somewhat easy to raise. good luck!!!!!
Grumps
Mar 4, 2021
71
The boat is sitting on the river bottom and the water is about 18’ deep.
Grumps
Mar 4, 2021
71
Can we see her with Googlemaps?
Only before she sunk.
Grumps
Mar 4, 2021
71
Grumps
Mar 4, 2021
71
UPDATE: Finally got the hull number and seems to be a 1985 model. Not sure about the length since the state has it as a 37 footer since 2014, but a 35’8” boat prior to that. The coast guard has it listed as a 35’8” boat. So, looking online, Hunter stopped making the 37 in 1984 and started the Legend 37 in 1986. Any input on what this boat actually be? I guess the hull could have been made in 85, but not made into a complete boat until 1986… maybe…. So, the saga continues…
Jun 10, 2024
202
Macgregor / Hunter M25 /Hunter 240 Okanagan Lake
I was hoping it was going to be on top of the water by now. :)
I sure hope you don't have to look at it all the time. That would be arduous.
