fresh water flush
Jan 7, 2011
6,000
Oday 322 East Chicago, IN
It’s best to have a seacock on barely-above waterline thru-hulls anyway, in case a hose fails when the boat is heeling. Not a super-high risk, but best practice. I know O’Day didn’t bother with that but some other manufacturers do.
Yes, it would be a best practice. I replaced all of the “above-water” thru hulls, and many are “barely”. Under motor, the cockpit scupper drains are definitely below the water line. But sitting in the slip, they are above.
A project for another day.
colemj
Jul 13, 2004
1,149
One final thought here, do you think the fresh water flushing crowd (FWFC) is in any way related to the people who ask you NOT to throw your used toilet paper in the head, but deposit it in the bin beside the head. Now THAT is really perverse.
What IS the world coming to ? ? ?
Man, you need to make sure you never travel outside your protective cocoon. A LARGE part of the world has those signs in every toilet everywhere. And a LARGE part of the world provides a trashcan for the used toilet paper. Like a boat, they are all plumbed with 1.5" PVC, with no easy way to unclog them other than to rip out the plumbing like needed on a boat.
Another advantage of fresh water flush - the macerator makes quick work of paper, and the outlet pipe doesn't scale up and narrow and get clogged.
Mark
Nov 6, 2006
10,246
I never understood the fresh water flush thing... until... I had to re-locate to a salt water marina for a while that didn't get water flow AND it had many ducks and geese and livaboards.... AND no pumpout facilities.. The aroma of the first flush with seawater was... striking! The temperature in the boat would be around 100F when closed up for a week and the sea critters in the seawater pipe to the head would stagnate, die, and ferment .. After the first flush, all was good, but MAN those first few pumps were odoriferous!! After the first pumps and with normal daily use, all was good.. My normal slip is on a fresh water bayou and the first flush is hardly ever a problem..
Likes: BigEasy
Dec 2, 1997
9,011
- - LIttle Rock
toilet
Does anyone know if there have been any psychological examinations as to "why" some people prefer to excrete into fresh water rather than sea water ?
No psych exams needed. It was only a few decades ago that all marine toilets were manual toilets. But then the marine industry began marketing to everyone with a pulse, most of whom didn't really want a BOAT, they wanted a floating condo...and most new boat owners still do. Toilets "like the one at home"....entertainment centers, central heat and air....microwaves...
And gone are the days when boat builders followed ABYC standards for things like all thru-hulls in accessible locations...seacocks aren't "decor" items, so builders bury 'em under companionway steps, in settees where they're buried under stuff stored in 'em. I could keep going for paragraphs.
8. One can go to extraordinary lengths to oxygenate their holding tank to stop odors, but it won't stop rotting organisms from stinking in there. The only thing that stops that is not having them there at all with fresh water flush.
You were doing pretty well till you said that. Fresh water DOES keep the toilet discharge line cleaner and reduces sea water mineral build up in it and the rest of the sanitation plumbing, but there's so much bacteria in sewage that whether you flush with sea water for fresh makes no difference in the holding tank., but oxygen does. Bio-physics 101: when organic matter breaks down in AEROBIC (oxygenated) conditions, it converts to CO2, which is odorless. It's when it breaks down in ANAEROBIC (without oxygen) that it generates hydrogen sulfide and sulfur dioxide gasses (stinky ones) and methane, which is odorless but flammable.
--Peggie
Likes: Clutch Cargo
Jan 4, 2006
7,779
A question if I may ................. do you advocate for full fresh water flushing all the time OR salt water flushing followed by a fresh water rinse ? Both will accomplish the same thing if the rinse hose enters the raw water hose at the sea water inlet thru-hull.
Dec 2, 1997
9,011
- - LIttle Rock
That's what makes teeing the toilet intake line into the sink drainline so handy on boats with below waterline sink drains...you can close the thru-hull to pull fresh water into the toilet plumbing via the sink. Without that ability you'd have reroute the intake line into a jug of clean fresh water every time you want to rinse out the system.
--Peggie
Jan 4, 2006
7,779
Thanks @Peggie Hall HeadMistress for interjecting that fact and straightening out the poster's #8 remark. I wasn't entering that disjointed mele for anything.
Yes all joking aside, that is the most likely reason for fresh water flushing as opposed to sea water flushing followed by fresh water rinsing.
My point here is that some people on this site (no names mentioned), over the years have developed the idea that using only fresh water in a head will eliminate any and all odour.
Jan 4, 2006
7,779
If I may offer, a valve could be added just past the "T" takeoff to the head and this would allow fresh water (from the sink) to enter the head for a final rinse before leaving the boat.
colemj
Jul 13, 2004
1,149
--Peggie
Yes, keeping an aerobic tank helps to eliminate odors. But few, and I mean few, boats can keep their tanks aerobic enough because of build and design constraints. The fact is that fresh water over salt water helps in this situation by reducing calcium carbonate buildup in the tanks (and that smell is not helped by aerobic conditions), and it dissolves waste products easier than salt water, which allows them to go aerobic quicker. This is the physics of it.
Many of the aerobic microbial species needed for waste breakdown without anaerobic sulfide production are highly attenuated by salt water, which makes the goal of properly aerating a salt water holding tank more difficult than a fresh water one. There is a reason open pit waste facilities use fresh water and not salt water for their microbe environments. This is the biology of it. https://pmc.ncbi.nlm.nih.gov/articles/PMC3208997/
If one is struggling to maintain a properly aerobic holding tank, then a switch to fresh water can give it a better chance. Fresh water does not make it aerobic, but it makes it easier to get and keep it aerobic.
Mark
colemj
Jul 13, 2004
1,149
Mark
Edit. Not to put too fine a point on this, but I just did some searching on the bacterial species responsible for both aerobic and anaerobic breakdowns of waste in holding tanks. I have a background in microbiology and chemistry, so this interested me. In all cases of aerobic bacteria, salt water significantly attenuates their growth and survival. E. coli, for example, has a 92% death rate in salt water, and Pseudomonas aeruginosa is similar, although a bit more tolerant. Meanwhile, anaerobic species like Prevotella thrive in salt water, although Bacteroides can be attenuated. The anaerobic bacteria outcompete aerobic bacteria in salt water, while they do not in fresh water.
Likes: dmax
Our experience is not consistent some of the statements made here. When we were on the Great Lakes we had much greater difficulty keeping holding tank odor under control. We'd often get odor from the time the tank was about half full until we pumped out.
Now, living aboard in salt water, we do not get holding tank odor until the tank is nearly full. Since we live aboard, critters dying in the intake lines isn't a problem, as they get flushed several times a day.
The head treatment protocol for both fresh and salt water are the same, some vinegar once a week when i remember to keep the calcification under control especially around the joker valve. And a weekly dose of Camco TST Max (amazon link). TST is an oxygenating compound that enriches the oxygen supply in the waste water.
colemj
Jul 13, 2004
1,149
Any thoughts on the difference between living aboard vs. occasional use? Any differences in pump out frequency? Any differences in the amount of oxygen being added to the tank via flushing frequency? Was this the same boat in each place, or different boats? Was salt/fresh water the only difference?
Mark
colemj
Jul 13, 2004
1,149
That product contains calcium nitrate as its active ingredient. Calcium nitrate doe not enrich the oxygen supply in the waste water. Instead, anaerobic bacteria will preferentially metabolize it instead of sulfide compounds, so the production of hydrogen sulfide is reduced. It does nothing to increase the aerobic conditions of the tank, and in fact promotes anaerobic bacteria by providing them with easier food (but it does help them not stink as much) The downside is the production of nitrates is increased, but at holding tank levels, this isn't as much of an environmental concern.
Mark
Mark
Odor from flush water in the bowl is much less with frequent use. Nonexistent in fresh water, unless the harbor water is polluted.
Long, meaning weeks, of sewage sitting untreated will smell worse than a shorter period.
With one aboard, pump out is about once every 2 weeks, with two aboard once every 7-10 days.
Not sure where you are getting your information. The main ingredient, about 70% is ordinary salt. The second ingredient is Sodium Carbonate Peroxyhydrate. There is some coloring and fragrance.
According to Wikipedia Sodium Carbonate Peroxyhydrate is an oxidizing agent often used in cleaning products. When dissolved in water Hydrogen Peroxide is produced in solution. Hydrogen Peroxide is an unstable chemical and the extra oxygen atom easily separates forming water and free oxygen. See the link below for the Safety Data Sheet on Camco TST Max.
Aug 7, 2021
168
O'day 28 Casco Bay
As some other members mentioned, Peggie's book is a marvelous reference and my head rebuild project would not have come out as good without it. Regarding odors, I went to considerable lengths to (more than!) adequately vent the holding tank; and as her book explains, is key to addressing the issue. This, combined with all new Saniflex hose, new head, "Y" valve, PVC pipe etc. has eliminated my odor problem. However, because the sink and fresh water tank are located on the starboard side of my O'day 28 and the head is on the port side, I could not readily rig up something permanent to be able to do a periodic freshwater flush. Also, space is tight and I decided to forego a second tank or bladder. Nevertheless, the solution I went with effectively kills two birds with one stone.
I found a company in Nevada that sells 316 stainless "garden hose" fittings (primarily for use in food processing plants) and installed one of these in the raw water inlet line between the seawater inlet valve and the the pump (see attached images). Once a week or so I break this fitting (after confirming that the inlet valve is closed!) and connect a hose which is long enough to reach the inspection port on the top of the potable water tank. I run enough FW through to slightly change the holding tank level and call it good. The second advantage of this setup is that I can winterize the head without removing any hoses. If anyone wants to know more about where to get this fitting, do not hesitate to PM me.
colemj
Jul 13, 2004
1,149
Yes, you are correct, thanks. It seems that the company has a "TST Max Orange" product, and a "TST Orange" product. I had looked at the SDS for the latter.
Mark
colemj
Jul 13, 2004
1,149
What I was asking is if your experience that fresh water caused more odor than salt water might be due to how the boat was used? Maybe living aboard in salt water has you flushing more frequently (higher exchange of oxygen), and pumping out more frequently (less time sitting anaerobically)? These factors are not salt/fresh dependent wrt odors. Also, it wasn't clear if this was the same boat, as different boats might have different waste plumbing designs. Boat waste systems are often notoriously bad designs from the factory.
Mark
Same boat in fresh and salt. Odor after a week of freshwater use, less odor after a week of saltwater use.
Reasonably well designed sanitation system with a PHII head, all new Saniflex hose.
Jan 4, 2006
7,779
I don't know where he gets it either, Dave. And thanks for being our fact checker. I would think that anyone who claims a background in chemistry would recognize "Peroxy" as an oxidizer.
Sorry, but I don't think our poster's smoke screen of plagiarized Google microbi text will ever be thick enough to cover up his classic fau pas of yesterday :
...............which was then reinforced with :
For God's sake man, you screwed up. No one is interested. No one cares.
GET ON WITH YOUR LIFE and go for a sail.
colemj
Jul 13, 2004
1,149
Are you OK? You seem to have easily triggered issues that are outside the norm in general, and this forum in particular.
Did you read anything I wrote? I already acknowledged I looked up the wrong SDS for a product with versions having two very similar names but different chemistry. It was an honest and easy mistake.
Everything else I wrote about microbe ecology is true, and easy to verify. So is the physicochemical nature of scale and waste breakdown.
Don't be jealous of my life and sailing - I'm doing OK.
