I recently redid my mast top VHF. Rewired with LMR-400, new 'Digital Antennae' antennae, All new high quality solder fittings. I'm not noticing any real difference from the old crap setup i tore out now that i'm finished connecting everything up. In fact, the only station i can get is WX channel 1. It comes in crystal clear always but i expected i'd be able to get more WX stations and just much longer range general VHF chatter.
My little handheld gets WX channel 1 and i can sometimes hear WX channel 5 on it when my mast top new setup can not get channel 5.
I'm starting to think my solder fittings, although very good quality fittings, i did not do correctly and probably negated all of the gains in the upgraded gear with poor soldering technique. Does this sound likely? I dont have enough experience to know what sort of improvement the better gear would give me realistically.
Would it be unreasonable to expect that I should be getting some fairly long range VHF conversations from 50+ miles away or more? I'm in Los Angeles and figured i'd possibly occasionally get some Navy chatter from San Diego. Not hearing a peep.
Do you think I botched my soldering? Before I redo with crimp fittings figured i'd get some experienced opinions first.
