What can I expect in performance gain VHF?
Jan 7, 2011
5,870
Oday 322 East Chicago, IN
Bad, this is ”water under the bridge” advice; however, you should have checked your old setup with a SWR meter before replacement. The old equipment may have been satisfactory. I purchase a SWR meter 10 years ago for approximately $20 on Amazon/Ebay when working on my rig. As @Don S/V ILLusion advised, you’re really going to have to check your rig with a SWR meter to determine if there are problems with the cable, antenna, & connectors.
Do you need a digital SWR meter, or is an analog OK ?
Greg
Jan 5, 2017
2,467
Radios can be funny things. A couple of years ago we were sailing off the west coast of Vancouver Island we could not receive any Canadian weather reports but we did get bar reports for the Columbia River and weather for Coos Bay. Not usual for VHF to bounce like that but it happens.
Nov 6, 2020
508
Mariner 36 California
VHF is line of sight, so you won't get greater distance from improved cabling and fittings. About the best you can get is 20-25 miles to another boat and that depends in part on how high their antenna is.
What you get is more transmitting power, or perhaps more accurately less loss in you transmitting power and less loss in receiving. This means someone 20 or 25 miles out (about the limit for VHF) will hear you more clearly and you will hear them more clearly. That doesn't matter until it matters, for instance if you are having an emergency and need help. It is also less frustrating when trying to connect to someone.
Little side note, That LibreTexts site is great! Nice reference to link. Going to go through the Engineering modules.
