I am about to start replacing the thruhulls and seacocks on my 2009 B37. I know the recommended approach is to use a backing plate and a flanged seacock. The current thruhulls are installed through the structural grid matrix, but the holes they cut are only big enough to fit the existing thruhull, backing washer and nut, so there isn't enough space for a full backing plate. I'm trying to figure out what to do. I think there are two options:
1. Enlarge the existing hole with a Dremel in order to fit the larger backing plate.
2. Fill the existing hole with thicked epoxy and install the backing plate on top of the grid.
Does anyone have any experience with this? Seems like a common issue, but there is very little online about the proper way to deal with the grid.
