Estimate??
Jan 19, 2024
10
Catalina 22 Sea of Cortez
Hi all.
I am thinking about hauling a Hunter 22 cross country.
The boat looks good, it's the right price, but I don't know anything about boat trailers.
I've been trying to find someone who works on trailers, in January, but none ever answer my requests for estimates.
The boat is on a single axle trailer I'm assuming is the original that came with the Hunter (the seller doesn't know as she's just a broker).
IF I were looking at having new tires and wheel bearings replaced, roughly how much do such repairs typically go for, this time of year?
Does anyone have any idea?
Thank you.
Mar 6, 2008
1,241
May I guess? 2 tires installed on 2 rims under $400.00. 2 axcle bearing at $40.00 each. Installation is done by removing the tires and a nut and pull the bearing out by hand. Clean and lubricate the axcel, insert the new bearing and install the bearing. One hour each axcel, about $250.00 for both axcels. Estimate Total $750.00 for a high estimate. If you are handy you can replace the bearing yourself. Watch a few youtube videos.
Jun 2, 2004
3,458
Any semicompetent mechanic can do the bearings. Tires can be had at most any WalMart.
My suggestion would be to buy four tires and replace the hubs then have the old bearings repacked and keep those as spares replacing the bearings if they are pitted or worn.
In addition to the tires and bearings the condition of the springs and axle should be examined as well.
An outfit that services RVs could handle the job and may likely be more familiar with that sort of work than a typical garage.
These may not be the size but are a good approximation and West's prices are probably higher than most places:
C E SMITH ST205/75R X 14 Radial Trailer Tire and 14 X 6 Galvanized Spoke Rim 5 X 4 1/2 Bolt Pattern | West Marine
C E SMITH Trailer Hub Kits | West Marine
Likes: Rxwoman
Jun 4, 2024
29
Hunter Legend 35.5 Charleston SC
Check the axle carefully if its been in salt water... We once had one give out in the middle from rust. The good news is, a Hunter 23.5 on the trailer just fit on top of a roll back tow truck.....
Likes: Rxwoman
-na -NA Anywhere USA
@Rxwoman
A private message was sent to you. First, I need to know what year is your boat as there are two different styles. Are there any brakes as that too will determine what I will have to say
Jan 19, 2024
10
Thank you,
I am handy, with the help of YouTube, I've done quite a bit of DIYs.
But not in January, as I don't have a garage or anywhere above freezing to attempt it.
That's why I'm looking to have someone else do it.
Jan 19, 2024
10
Lol, that's what I'm afraid of happening, and intend to have new tires and good bearings before leaving.
Fortunately I very much doubt it's seen salt water, considering we're pretty land locked in my neck of the woods.
And thank you.
Jan 19, 2024
10
Thank you for that.
I intend to carry spare everything, and would attempt the repairs myself, if I had somewhere out of the cold to do it.
But I don't. Hence my looking for someone who does.
Thank you.
Jan 19, 2024
10
I have watched several YouTube videos.
It doesn't look too complicated, just very messy, lol.
I would have attempted the procedure myself, we're it above freezing here.
But not this time of year, in my driveway.
Thank you.
Mar 6, 2008
1,241
Rxwoman, yes it is messy. Wear latex gloves from Harbor Freight, use bearing grease for the axcel. Then have a hot bowl of chowder and French bread.
@Rxwoman
Hunter built two 22 foot boats the first in the early 1980’s and another 22 that replaced the plastic 216 which is no longer built as Marlow Hunter closed its doors two years ago. When responding, I try to get all information first to respond to the question; therefore, Ian only talking about the trailer only. The boat is a 1983 model with a trailer thru a broker. I do not know the year of the trailer but I will assume it too is a 1983 model without any history nor even maintenance schedule information.
If a 1983 model trailer, then there is a lot to look at.
1. Tire tread and dry rot
2. Brakes if any to see if they work
3. Hubs and bearings/racers
4. Trailer lights
5. Axle rust/deteriation
6. Leaf springs
7. Winch stand, winch operation and strap/safety chain
8. Check frame for rust and broken welds
9. Check the weight loads of the tires
10. Spare tire and hub
11., check the wheel fenders
12. One photo of trailer showed only two bunk board
supports each side. Suggest a third bunk board
support each side. Suggest looking at bunk board
Integrity.
13. Check for keel tray integrity.
Due to the strong possibility that this could be a 42 year old trailer and not knowing the overall integrity, I strongly recommend hiring a professional for inspection and recommendations of the trailer. Boat trailer is one thing but human life is more important!
Dave Condon
