I put the ARG 750 Groco strainer, that
@jssailem and others mentioned right in front of the alternator and a little bit left, mounted to the front wall of the engine compartment. Easy access via the top engine compartment access cover. I had previously moved the fuel filter so there was plenty of room for the water strainer. it is a couple of inches above the water level.
And like you
@Project_Mayhem , mine had the small plastic stainer with screw on plastic bowl that looked like a disaster waiting to happen.
