The boat is a Morgan 22. Motor is 6hp Tohatsu. See the photo of how the motor mount is set up.
The block of wood is attached to the mount by 2 screws which go all the way through the wood. Then the motor clamps on the block of wood. I bought the boat in this configuration and it seems to work well. I've noticed some splintering/rot on the wood block so I want to replace it.
What kind of wood would you recommend for this use case? Can I use "Southern Pine", which is readily available at my local Home Depot? Also, not sure if I should use "pressure treated" or not. Thanks.
