Noise between Mast and Boom
Jun 5, 2018
51
Beneteau 35S5 Buffalo, NY
I'm experining a loud sqeaking noise that seems to coming from the area where the mast and boom connect. I have put SailKote dry lubricant on it which stops most of the sound. Is anyone aware of anything else I can do to stop the noise
Thanks,
KFG
e
JBP-PA
Apr 29, 2022
787
Jeanneau Tonic 23 Erie, PA
Some goosenecks have (or are supposed to have) plastic bushings which tend to wear out resulting in metal on metal contact.
1,493
Raise and lower the boom by hand near the mast and listen for squeaking sound. If squeaking, then install plastic washers on the bottom of the gooseneck bilt lifting the boom slightly. Then try to move the boom up and down and listen for the squick.
Ted
Jan 26, 2005
1,278
If you have a boom vang, snug it up slightly to prevent the boom from moving up and down too much.
Likes: D Swanson
Jun 5, 2018
51
I was thinking there must be something that would prevent the metals from rubbing togother.
I let you know if it works.
Thanks
Jun 5, 2018
51
It turns out the noise was not coming from where the boom meets the mast. The pin that goes through the bracket securing the
Forespar Yacht Rod Boom Vang to the mast seized, preventing the bracket from swiveling as the boom moved across the boat causing the bracket to bend see attached picture. The noise was the rod of the boom vang rubbing against the bracket. I'm planning on calling Forespar on Monday to see if they still sell the parts. If not, any suggestions on who might sell used parts?
Thanks for all your follow up it was helpful>
Wow. It’s nice to discover the problem. Bring the sound of silence to your boat.
You may not be able to find an off the shelf solution. I would seek a local machine shop. Ask them to build one.
Likes: JBP-PA
Jun 5, 2018
51
If I can not find replacement parts or have the current one repaired I can still use a non mechanical boom vang system. Although, I will need to attach a cable to the back stay to hold the boom up. Does any one have any suggestions on how to attach a steel cable to the back stay ?
Thanks for your follow up it's helpful.
Ouch... Please help me understand when you need to hold the boom up.
If you are sailing, the sail holds the boom in place (or at least should). If you are at rest, attach your main halyard to the end of the boom. It can serve as a topping lift while you repair your rigid vang.
Jun 5, 2018
51
Hello All, As it turns out the swivel and bracket for my Forespar Boom Vang are not OEM parts. I was able to have the swivel
reinforced. I want to make sure I reinstall it properly. However, there is no user manual on Forespar's web site, I also called and have not received a return call back. If you know where else I might obtain one or have one can you send me some pictures of it so I can see how it is attached.
Thanks so much
Kevin
I'm shocked and appalled to learn that a PO didn't use OEM parts for a repair. That almost never happens! When an owner breaks something they always source the original parts even if it takes weeks of a short season of down sailing time. And if it turns out the parts aren't available because the builder went belly up two decades ago, they scrap the boat and start over.
So I'm kidding but my point is that if you buy an older boat you should not have the expectation that it sports original equipment. Every boat owner I know will do nearly anything to keep his boat on the water. And modifications are fun! So for older boat "New to me" owners don't make any assumptions about equipment.
PS: Goosenecks are a problem because builders use so many different hardware options and the hardware is under many stressful forces and movements. There isn't much of an aftermarket option for older boats. Without a gooseneck you've bought a nice garden ornament . I bet most buyers hardly look at the gooseneck.
