Some sailing content in the latest music video from my current band.
No lyrics with this project. Our previous band had plenty of lyrics and a few great vocalist, but the subject matter is definitely not appropriate for this board.Awesome scenery, great riff. Where’s the vocals? Come on man even Robert Plant could write the lyrics for that tune!
Good to hear you like the video. The snow & ice scenes are from Alaska. Lead guitarist lived their for two years and is now in Bellingham, WA.Nice video, Phil! The snow and ice at the end is definitely not Hawaii.
Wait John there’s more . . . as the story unfolds. If you look closely above the large propeller you will see 2 more propellers, 1 on each side of the pulpit. They are for side thrusting or as we sailors call them bow thrusters. I understand that they actually work. How well I don’t know as I have yet to discuss with the owner.WOW... Len...
SO the solar panels proved power to spin the airplane prop pulling the boat through the water...
Is that the engineering?
I'll throw one in.Photo day appears to be on life support
Whoo hoo, John!Whoppie, WOW, Oh Boy!
My engine started on the second go.
That wasn't a painting, it was a video!Thanks, guys, for the sailing images. I did not have my camera, but maybe I could paint a picture with words.
There was a bit of worry, as we had just covered over the big 26 by 29 inch hole cut in the bulkhead during the engine removal. Once closed up, the fuel filter and lines had to be removed and attached ( this time) to the outside of the bulkhead. We took care to keep the fuel in the filter and lines as best we could. Hopeful we would not have to prime the fuel lines again. Success was earned.
In addition, All of the electrical ground cable connection blocks were located on the new bulkhead above the water line.
With the engine started, I untied the lines and took the boat out of the slip to set her back in the slip bow first. It felt great to have the boat moving through the water. Guiding her back to her slip, my skills were a little rusty. I delayed the turn from the fairway into the slip too long. The slight breeze on my back caused me to move past the end of the slip. I love boat handling, so I spun the boat around and headed back out into the marina to set up the approach again. The second time was the charm. I glided into the slip and lassoed the first cleat with the spring line. I snuggled up to the dock. Stepped off and secured the boat's lines. Back on board, shut down the engine, and a grin spread from ear to ear.
A few more minor projects, and I'll be able to go cruising. The big win was the change in sound. The hole in the bulkhead standing in the salon with the engine running made the noise level an unacceptable 88 decibels. Once the hole was patched, the engine sound was down to 70 decibels. This was a much improved sound level. I suspect I can get it into the 60s with a little sound-deadening insulation on the engine side of the bulkhead.
