I have a Catalina 27 with a harken jib furler. Sail came out fine but was binding when trying to roll up. The top swivel was spinning with the inner tube thing that the sail wraps around. This caused the halyard to also wrap. I noticed the halyard was frayed due to this issue over time. I tightened the halyard and it snapped. When I dropped the jib the upper swivel was smooth and not binding. Perhaps with the pressure from the halyard caused it to bind under load ? Not sure why it was spinning fine with the sail off but not when up under load ? I now have two problems, my furler and a snapped jib halyard. I have a spinnaker halyard available, could I use this the raise the jib ? And then fix the other halyard when I lower the mast for winter ?
