Lets go back to the :Short Sail", problem.
As you can see from the pictures I got the cunningham hook and attached a frictionless ring to pull tension.
I did a test run on short sail adjustments and fund that I will also need to add a plug below the gooseneck, because when I drop the sail to move the hook to the first reef point the gooseneck falls to the bottom of the mast.
