UPDATE:
Yesterday i started to disassemble the Volvo MD22L-B to remove the coolant pump. I have a new pump on order from the UK that is supposed to be here in a couple more days.
In order to get to the coolant pump, the timing belt must be removed and the pulleys on the crank, cam, and injection pump need to come off. Then the back half of the timing belt housing is removed to expose the pump.
Many thanks to @jviss for coming over to help and lend moral support as well. And for making run to Harbor Freight to buy tools I missed bringing from home.
The timing belt removal was easy since I have done that job twice previously. Getting the pulleys off was also easy with the help of a big DeWalt electric impact wrench to loosen the bolts and nuts and a flat plate puller from Harbor Freight.
I've drained the antifreeze and I'm at the point of removing the coolant pump today. I'll clean up everything in preparation for re-assembly.
Here are a few pictures of the progress-
