Greetings!
There are many "traditions" regarding electricity and system management on sailboats. At one time it was the generally accepted practice that one had two house batteries and alternated use of them on a daily basis; hence, the 1-2-BOTH-OFF switch. That practice is fading into obscurity. Another ancient practice that I believe is still dominant is that bilge pumps be powered directly from the house battery, so that if the 1-2-B-O switch is OFF, or the main breaker is OFF, the automatic pump will still be energized, to spring into action should the boat begin to flood.
I never understood the logic of this, and have never heard a compelling reason for it. The only reason I was given once was that if someone saw that your pump was running, they would alert someone, or go ahead and try to save your boat. I find this dubious. And, in the case of my boat, you can't see the pump output, anyway.
So, I am inclined to not follow this practice, or at least to connect the pump to the batteries through a low voltage disconnect, so I don't end up with a flood and a dead and damaged house bank.
What say you?
What say you?
. Then if the bilge pump comes on to save you from a failed shaft seal, you're not going to run down the batteries.
