I just bought a 1998 Tartan 3800. It is cosmetically in great shape, but as with any 26 year old boat there are some issues. I have been reading through your posts and recognized some things. We finally got it out for a couple of hours sailing (delay due to nine grandkids, a new puppy, medical appointments, etc) and were really happy with the performance. There is one issue for which I would like to get your input. My courtesy lights didn't work. When I opened the breaker panel I found the purple wire (power to the courtesy lights) was not attached to the "Courtesy Lights" breaker, but was instead connected to a blank breaker (no toggle on the front of the panel) and there was no continuity between the purple wire and the lights. I then discovered another purple wire connected to a fused 12VDC buss behind the breaker panel. I then discovered a courtesy light buss under the bottom drawer at the nav station, but not powered. In trying to trace out wire paths a purple wire came loose from under the nav station that apparently had corroded off. This wire was a direct connection to the 12VDC fused buss behind the breaker panel. If it was connected to the courtesy light buss under the drawer all the courtesy lights powered on (and without a switch no way to turn off). So I disconnected the purple wire from the 12VDC fused buss and connected it to the "Courtesy Lights" breaker. Now the courtesy lights are turned on and off via the breaker panel. However, I also discovered a rocker switch at the top of the companion way that has two purple wires attached. This makes me think a modification was made to bypass the "Courtesy Lights" breaker and to operate the lights via the rocker switch, but due to a broken connection somewhere under the nav station this no longer worked. My question: Do your boats have a rocker switch at the top of the companion way that operates your courtesy lights?
Mellis,
Congrats on the boat!  We have a 98 as well, hull #37.  The courtesy lights have all had to be replaced on our boat except for the vberth.  They are a very finicky type of light and the old school bulbs get very hot.  Each light has a number crimps behind them that are a potential failure point as well.  I believe all of the latter 3800 models had a rocker switch at the companion way.  The smaller buss with fuses behind the electrical, mounted to the hull, is an (always on) bus.  This is where circuits that always need to be on should go ie bilge pump, courtesy lights exc.  These circuits will have a switch down stream from the bus to control them.  When you come to the boat, and the entire panel is off, you can still flip the courtesy lights at the companionway to get into the boat.  However, Jubilee has a breaker in the aft cabin that is upstream and will completely cut all power to the electrical panel and circuits behind the panel.
I hope that helps.  We bought Downtime (now Jubilee)early 2022 and have sailedher from Florida up the east coast to NC, and back down to the Bahamas the last 2 years. She is an amazing boat!  We are almost always faster than any of the boats we cruise with (some of them as large as 60 feet), and we almost never run the engine.  Our boat was pristine cosmetically, although a couple of years living aboard in the tropics has dropped her down a notch. She was almost all original, which I much preferred so that I didn’t have to chase down issues that the previous owner screwed with.  However, that ment that many items need to be serviced or replaced as they were at the end of their life and some failing.  New gear includes Windlass, electronics, refrigerator rebuild, lighting, fans, Watermaker, offshore internet/WiFi, solar on the davits/Bimini/ and dodger, 600ah lifepo4 bank for start and house, high output alternator, steering quadrant, among other things.  Almost everything else has been serviced in the last 2 years including rudder bearings, engine mounts, all pumps rebuilt, furler and winches serviced, and the list goes on.  Currently doing engine compartment insulation, alternator regulator, and control cables.  Looking to drop the keel this year or next to inspect bolts and service the joint and start rebedding all of the deck hardware/ports/hatches.
