He only posted his question last night at 7:45 pm. He may still have a day job that doesn't allow him time to visit the forum.I'd like to know if we are going to hear back from the OP.
Good point. If so, he needs to quit his day job. Priorities, man!He only posted his question last night at 7:45 pm. He may still have a day job that doesn't allow him time to visit the forum.![]()
I thought perhaps the front was over weighted? It does sit wellNo. The c22 hulls don't have coring. Fiberglass doesn't absorb water like wood or foam etc. Are you asking because the boat isn't sitting level on it's water line ?
(Most c22s sit a little low in the stern unless you put more gear/weight in the bow. Keeping the boat flat improves performance)
I think it was 5% up last time I sailed; I noticed when we headed in- it just wasnt completely 100% down, a little kickedup, I am unable to find the picture. My club champion told me that would be minimal issue but I did wonder!Take a look at your rudder too, if classic tilt up may not be holding all the way down which will give you a weather helm constantly.
I will get a pictureTake a look at your rudder too, if classic tilt up may not be holding all the way down which will give you a weather helm constantly.
Okay I wrote that down. I get sail with a national champ next week. This will be 4th summer stumbling around with this boat, my club champ went out last month with me and as we tried to round the mark, he shook his head, "I dont know what but something aint right. Its unbalanced" was all he could sayAn old, stretched out, baggy mainsail can and does cause weather helm. The bagginess allows the draft (deep, curved part of the sail) to migrate aft, moving the center of effort of the sail plan aft, thus pushing the sternward portion of the boat away from the wind, which causes the bow to turn up toward the wind.
Depending on severity, you might attempt the following. Rig a Cunningham if you have a cringle in the mainsail for one. Tightening it will pull the mainsail draft forward. Ease your traveler to full leeward when the boat begins to become overpowered. Tension your backstay adjuster if you have one. This should flatten the mainsail near the top of the mast, reducing the heeling force there. Either recut your mainsail or get a new one if it is old. Anything over 10 yr most, I think, would agree is an old sail. Of course, use the properly-sized headsail for the conditions. If you depend on roller furling of the headsail then it should be “reef-able.” That is, the headsail is cut and made with a foam luff that allows reefing of the headsail.
As for the bottom, board, get them cleaned up. Get to work!!
Thank you for your time. I just so dang confused we have a lotof "dirty bottom" catalina 22s at my clubNothing is going to help the problem if that bottom condition Isn’t fixed first.
Absolutely. And it takes time at the helm of a boat that sails well to get to the feeling not thinking stage. We don't think when we ride a bicycle, we just ride. Same with sailing, only it takes longer to get to that stage however, you get fewer skinned knees.Sailing is a lot more about feel than knowing.
The bottom is beyond dirty. The centerboard is in serious trouble. To win races you have to start with a clean bottom and be on time at the start.Thank you for your time. I just so dang confused we have a lotof "dirty bottom" catalina 22s at my club
Good to know of the terms. Thank you.The term weather helm comes from the position of the tiller, which will be to the windward side. The opposite is lee helm when the tiller must be pushed to the leeward side of the boat.
A little weather helm is generally good. Lee helm is always bad. If the boat has weather helm it will want to turn towards the wind, thus if something happens a tiller breaks (been there done that) or helms person drops the tiller the boat will turn into the wind and stop. In the same situations with lee helm the boat will turn down wind and run off or jibe.
The bottom and keel need serious attention.
Helm issues that you describe can be caused by poor rig tuning, worn out sails, poor sail trim, improper mast position, or the keel being off center.
How old are the sails?
How did you tune the rig?
Are you sure the masthead is centered over the midline?
No. Centered over the centerline of the boat's hull."Are you sure the masthead is centered over the midline?" Are you talking about mast rake?
Took me a year to clean her up. I have minimal access to hoists and trailers, and all the keel techs have retired in my area. I do watch all these other dirty bottom old boats cruise around in delight- slower but they obey. I have read and read all the minimal adjustments that can be made to get those tweaks for racing. After the last sail with my club champ; he left scratching his head. I'm going on a fourth summer now thinking I might have to dump my boat.I think we are being punked…![]()
5% up make a difference? seriousTake a look at your rudder too, if classic tilt up may not be holding all the way down which will give you a weather helm constantly.
definitely not a racer, I long to sail into my cove for once, keep missing my marksThe bottom is beyond dirty. The centerboard is in serious trouble. To win races you have to start with a clean bottom and be on time at the start.
It was low wind that day 2/3mph low wind to 9/10 mph the highest point. Used my big jib. I thought hell, if I just used the storm jib it might have sailed well for once.What size jib in what knot wind? (I had a 1981 C22 for many years, it sailed great.)
I guess I will take a right angel or my protractor out again, cause eyes aint cutting it. Measurements taken via halyard markingslast week, they were 1/2"off port sideNo. Centered over the centerline of the boat's hull.
Sailing lessons came before the boat, chose to do the instructor sailing cause surely I am missing something here and it was free. I picked the boat up dirty and unused for $200. It is beyond me why she misbehaves so bad. Disappointed. Looking into my keel pin and keel shape options.I think you should have spent some of the money that you spent on sailing lessons on maintenance. That centerboard and hull would prevent your boat from sailing well on any point of sail.
The only way to get really good at sailing is to sail. And sail lots more. And sail lots more, etc. Sailing is a lot more about feel than knowing.
Good luck.
