raymarine ev100 vs cpt autopilot
Nov 22, 2011
1,303
Ericson 26-2 San Pedro, CA
I wonder if anyone has ever "hacked" a CPT pilot to add features, like steering to a wind angle, or to a waypoint? If I could pick up a used on
I did a lot of research while considering the two. I do coastal cruising with a lot of change of direction due to narrow passages (Puget Sound) and had no real need for waypoint tracking. For me it came down to the use during the worst of times while single handed. That is the primary reason I have a AP. All other uses are considered convenient. The EV has a significant history of broken and worn down internal parts within the stearing belt system over time. For these reasons I went with the CPT. Customer service was top notch. Installation was straight forward with exceptional documentation. The only down side is that it is bulky and I would like a wireless remote option. I’ve had it for about three years now with no regrets.
I don’t buy into the shear pin argument. Shear pins are designed as a weak point and sacrificial. You should always have back ups ( several) for any sacrificial element. Imagine what would have happened ( probably only applicable to those who know the CPTs strength) in the same situation with the EV?
Exposed drive belts can be minimized in the configuration of the system. Mine is so low pro that it is a non issue.
By the way: Though this would add more cost, you could always control the CPT motor with a Pelagic Autopilot controller. The electronics are more advanced than the CPT, but you'd benefit from the robust CPT drive motor. The Pelagic could control any 12-volt drive motor, so it should work just fine with the CPT--though you could call Pelagic and ask what their experience might be with interfacing to the CPT. Bet you anything they would be able to answer that for you. Just a thought.
My Ericson 26 is tiller steered and I use the Pelagic with their tiller actuator. As an apples-to-apples comparison, I ditched my former Raymarine ST2000 tiller pilot and got the Pelagic. There is no comparison. The Raymarine unit is more or less a toy, and the Pelagic steers the boat in conditions the Raymarine wouldn't touch. I had an ST4000+ on my previous wheel-steered 30 footer and thought the same thing about it.
Jun 25, 2004
640
Hunter 306 Pasadena MD
I've had a Raymarine ST4000+ since 2004, and had to replace the external wheel unit (plus motor, which actually hadn't failed) maybe last year(?), although they never really failed: just got squeaky. The electronics have functioned perfectly. I won't compare the 2 units under discussion, but I do have a comment about longevity. Get a high quality sunbrella canvas pedestal cover, and use it 12 months a year. You're protecting all of your electronics from not only UV, but also heat, rain, wind*, wind-driven rain... etc. Someone commented earlier on the rubber rotting out on their Raymarine unit. Ours worked flawlessly for 18-some-odd years, except that it got squeaky, and when I took the wheel unit off, it was broken in several places, but still working. I think having it covered all that time made a huge difference.
* Ok: maybe not wind. I made that part up.
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
I always wished someone made a really nice, really rugged, mostly metal sailboat wheel drive, that looked nice, matched the aesthetics of sailing boats, was quiet, rugged, and bulletproof, and had a solenoid-activation option. Maybe even some nice, chrome or stainless levers for AUTO, STANDBY, +/- 1º, 10º, etc. It would probably cost more than I would care to spend! Ha, ha. Also, i wonder why Edson or Lewmar never integrated a pilot motor into one of their steering pedestals (that I know of).
I guess one reason is once you start bumping up against what that would cost, you decide to go with a below-decks drive, which has advantages not found in wheel steering.
Likes: skob1014
Jul 1, 2010
990
Catalina 350 Port Huron
Thank you all for your great comments. If I got the EV100, it would be completely standalone because I don't have any navigation system on my boat -- so lack of integration is not a concern. It seems like the simplicity of installation and components is a benefit of the CPT. Maybe it will be overkill for Lake Ontario but it would be easy to transfer it to a bigger boat if I get ambitious. Looks like CPT is the better choice for me.
I don't think you'll regret the decision to get the CPT. While I've never used one, that would also be my choice for a wheel pilot. I put an EV100 on our previous boat (Seaward 25). While it worked well enough most of the time, it did have issues with following seas when the waves picked up (we usually turned it off then), had issues with noise, and had the boot on the motor fall apart from the sun. No comparison between that one and the under deck Raymarine 4000 that is on our other boat (it works flawlessly no matter the conditions).
Apr 24, 2023
23
Hunter 28 Rochester, NY
Thanks, I went ahead with the CPT order. I think I'll be very happy with it.
Jan 7, 2011
5,999
Oday 322 East Chicago, IN
Do you not have any wind instruments?
I finally got my wind instrument (Tac Tic wireless) to interface with my Garmin CP and my Raymarine AP so I can keep the boat on a wind angle…particularly helpful when raising and lowering the sail.
jviss
Feb 5, 2004
7,090
If I had a boat that didn't have an autopilot already, and I decided to go with a wheel pilot, I would get the CPT, no question!
Likes: skob1014
Apr 24, 2023
23
I have no instruments at all. The boat had an out-of-date garmin unit that died. I don't expect to replace it, just use my tablet.
Nov 6, 2020
589
Mariner 36 California
For a completely standalone pilot with no desire to steer to the wind I think the CPT is the hands-down winner, if the increased cost is not a strain. The open belt issue was addressed in another thread, where one owner said it's a lightweight belt that's easily torn off by hand if it comes to that. The shear pin issue can likely be solved, as people have put this pilot on 63' yachts! One enormous advantage are the rudder and deadband knobs, in my opinion.
I know this is a dated thread, but just installed a CPT on my boat. I agree, its really a non-issue. The belt is not tensioned tight enough to be a hazard to an adult. Maybe a very young child could break a finger if it got between the wheel and belt but even then i question that. Any adult could grab the belt and yank it off but in most installations, i think someone would really have to try to get a finger jammed in it. Clothing would be more likely but even then it would be unlikely and just a nuisance. I would be a very simple to fabricate some sort of shield if very young kids were around the helm while cruising.
6,432
Catalina 320 Barnegat, NJ
I saw a CPT autopilot on an Allied Princess Ketch just yesterday and talked with the owner. I don't think I would choose to buy one because of the open belt arrangement. It basically limited access to the area behind the wheel pretty significantly, but you could easily step on the seats. His boat has a worm-drive wheel without a pedestal. I think with a pedestal it would even be more cumbersome. Although, our discussion indicated that the unit works very well, I think I would not choose to install one. If I were shopping for a small Hunter sailboat, I would probably dismiss one with a CPT autopilot rather than a RM wheel pilot. It may limit your re-sale opportunities. Mounting the drive unit and control unit also looked to be relatively invasive (holes thru the fiberglass). Aesthetically very unpleasing as well. It looks like very old-school technology, which turns (most?) people off, I think, regardless if it is a good product or not.
OOPS! I just noted the date! Hopefully it is working out well for the owner!
Nov 6, 2020
589
Ha! sorry. I dont like to resurrect old posts but somehow came across this one from last year. I had just finished wiring mine so caught my attention.
I guess it depends on the setup and how well its done. Yeah i can imagine on some boats its a pain but on a standard pedestal its a very neat and organized setup. Here is a pic of mine (back view). The drive unit is tucked off down on the bottom of the pedestal and sits within the confines of the wheel and the binnacle support bar. Wiring still looks a little messy in the pic. I have since tidied that up. I did some sea trials on tuesday and it was never in the way. It doesnt stick out at all and sits resonably high off the floor so it doesnt get kicked. The control head is also pretty small. It looks big in the picture but clamps neatly off to the side of the binnacle support bar. I only had to drill two holes in the stainless support bar to run the wires down through the cockpit floor.
1,945
My pedestal mount is with clamps. No holes for anything. I have yet to hear anyone discuss a CPT breaking. I read alot about gears and plastic wheel failures with the other designs. Value wise, it would go with me and no the boat if I sold.
Nov 6, 2020
589
Your installation is very similar to mine, however I have a 42 inch wheel and a binical hung table so it would be almost impossible to stick anything into the belt by accident.View attachment 227452 Great addition to any boat.
Oh nice. Yup pretty much exact same setup. My wheel is pretty small. I forget, maybe 32" so easy to get around the pedestal without bumping the control head. IMG_2652[1].JPG I kind of like the old school look of the CPT :p. Got some fair weather this weekend so will be nice to get final sea trials done and get it dialed in so i can go out in the bay by myself when no one is around to go sailing.
Jun 11, 2004
1,933
Oday 31 Redondo Beach
How easy / hard is it to remove the wheel when you need some room in the cockpit for guests while in a slip or at anchor?
Thanks
Nov 6, 2020
589
Thanks
Very simple. The CPT drive unit has a quick release lever. You can see in the pic i have my belt loose. All you would have to do is release the tension on the belt with the quick release, remove the steering wheel nut and slide it off as usual. The drive wheel for the CPT mounts to the wheel spokes only so does not interrfere and the belt just pops off once the tension is released.
Likes: Richard19068
Dec 28, 2015
1,945
I'm not really understanding the attention given to the belt being exposed and something getting caught in it. The belt doesn't have to be very tight and the minimal amount of movement makes it irrelevant. My only issue I have with mine is I have to reach around the unit to disengage it. This was a result of my decision making. I could have ordered it configured opposite to easily due it while at the wheel.
