I use antifreeze 50/50 for my M25XPB 2001, I have no issues with over heating. Last year I started to see some rust colored water under the engine and eventually had a loss of coolant when I checked the manifold. I found that the fitting from the manifold which went to the overflow tank was clogged and the hole to the manifold was also clogged. I fixed these issues. I have drained the coolant from the drain on the Heat exchanger 3 times and it still comes out this rusty brown color. The coolant does not appear to be leaking. The coolant I use is a 50/50 mix color is green. I am guessing I have rust in the engine. The bottom line is I have no overheating problems. What would be any suggestions. It appears rusty looking antifreeze will still do the job cooling the engine. Any suggestions would be appreciated. Attached is a picture of the coolant color.
Thanks,
Mark
Thanks,
Mark
