Wiring solar and ACR’s
Aug 17, 2013
970
Pearson P30 202 Ottawa/Gatineau
Hello everyone, I just received my solar charge controler, still shopping for the panels, getting hyped about the upcoming season, but before I splash I have a very long to do list.
wiring the solar panels is straight forward, what I’m not sure is how to send the power to my 2 battery system, do I just wire it to the 1-2-both switch and be done with it ?
is an ACR necessary? If so how do I wire that in my system?
I will also re-wire the mast and a few other systems, easy enough to do.
Nov 21, 2012
716
Yamaha 33 Port Ludlow, WA
Wire the controller to the DC bus if you have one, or directly to the battery switch if you must. ABYC specifies no more than 4 lugs per terminal so be cognizant of that limitation and install a busbar if you will exceed it. Be sure to fuse the controller output, based on the wire size. A disconnect for the panels is also recommended.
It all depends on how it is wired now, and you didn't tell us.
Let's assume your alternator output goes to the C post of your 1-2-B switch, which means your switch determines both what gets charged and what battery bank(s) gets used.
Unless you want to leave your battery switch in an on position when you're away from the boat, to charge both banks automatically, you'd need something to tie them together when the switch is off.
If your solar panel is small compared to the size of the bank(s) your panel may not even have enough power to raise the system voltage high enough to trigger an ACR, which usually requires over 13 V to engage and combine.
So more info is needed, like bank size(s) and panel size.
970
I haven’t yet bought the panels, still looking at all the options, but it will be between 200 and 400 watts, the contrôler I bought is a 40 amp.
As for the batteries, I will need to go to the boat and check as I don’t remember at the moment, but I’m thinking around 100 amps each, there are 2 batteries
NYSail
Jan 6, 2006
3,137
Beneteau 423 Mt. Sinai, NY
How is your alt wired? I have all charging sources going to house bank via a bus bar. Then use an arc to charge to start battery. Simple enough and don’t have to think about switching dials.
leo310
Dec 15, 2006
646
Catalina 310 44 Campbell River BC
What I have done is used a Victron FET to charge house and starter batteries directly I also installed a inline fuse too. You could do the same using an ARC only thing diffrent is the solar would be to the house then ARC too the starter and if I remember the only time the starter battery would get a charge is if the house was fully charged using the FET they both are charged all the time.
DArcy
Feb 11, 2017
1,768
Islander Freeport 36 Ottawa
I set up an always on bus bar for things like the bilge pump, fridge etc. I wired the solar panel controller and battery charger here so I can shut off the main battery switch and still allow charging from all sources. I then use an ACR to combine the chargers with the starter battery (bank 2). I have the 1/2/Both switch set up so I can combine the banks if needed, for instance if the starter battery is dead. I normally operate with the switch set to 1.
DArcy
Feb 11, 2017
1,768
Hey Darcy, what are those numbers on your diagram? Wire size?
Yes, the numbers in line with the wires are gauge size. I followed this diagram when wiring the boat and it was handy to have everything in one place.
Likes: fred1diver
DArcy
Feb 11, 2017
1,768
I am wondering what is the purpose of the other switch between the ½/both switch and the ACR?
I like this diagram, just wondering about that switch, is it the ignition switch?
The 1/2/Both switch is to allow starting the motor from the house bank. In theory I could run the house circuits off the starting battery if I disconnect the house bank as well. I only used a 1/2/Both switch because it was already there. I would probably go with separate on/off switches if I was starting from scratch.
The other switch (on/off) is to turn off the starter battery or to isolate it in the case of starting off the house battery when the starter battery is dead. I turn it off when leaving the boat as a theft prevention, the switch is inside a locker so not easy to find.
I just realized now, it is not a good theft prevention, anyone could just switch the readily visible 1/2/Both switch to both and the motor could start :confused:
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
@DArcy wondering why you can only power your radio from the house bank. If that bank fails, it doesn't appear you can power the radio from the engine battery.
Aug 17, 2013
970
Ok, I will need to look into that, my system is wired so I can start from either of both at the moment
jviss
Feb 5, 2004
7,089
I question needing to start with both. If one bank has failed, it's best to keep it isolated from the good bank, to avoid draining it. It's also good, in an emergency, to be able to run house loads from the engine battery, presumably with the engine running.
Aug 17, 2013
970
I inherited the po’s electrical nightmare, trying to get everything to code. It is a 51 years old boat so a lot has been done in the past years
DArcy
Feb 11, 2017
1,768
The radio in the diagram is actually the memory for the automotive stereo. The VHF is powered through the DC distribution panel just like most other DC loads. As mentioned above, I can run the house DC off the starter battery if I need to by switching to Both.
