- Oct 22, 2014
- 23,789
I saw this on the attached video. Instantly, my mind wondered. How it might be used in a sailboat.
It would make a perfect anchor.How it might be used in a sailboat.
It is not about going forward or backwards. It is about facing the challenges of the various motors and discovering alternatives that resolve the limits of current understanding.Why go back to a new type of IC engine when the world is trying to going forward with electric engines.
This is not just now discovered idea. In 2016, the company was working with Peugeot to use the push-pull engine design to extend the range of their electric car..The video is not real so no prototype yet
Yes, but how would its holding power compare to one of the new generation of anchors such as the Rocna or Mantus?It would make a perfect anchor.
… and how can we use existing diesel engines to secure moorings?Yes, but how would its holding power compare to one of the new generation of anchors such as the Rocna or Mantus?
Seems like we need another anchor thread to debate this.
Nikola Tesla had proposed the efficiency of a steam train would be improved if the steam engine were used to maintain battery charge for an electric drive motor. In the case of steam, he was likely correct since the boilers had to be kept hot even when the train was sitting still refilling water, loading passengers or taking on more coal. To convert this extra energy to electric storage meant the boilers wouldn't need to labor on long uphill runs and could stoke the steam engine at its most efficient rate.A heat engine is limited in its efficiency just by the laws of thermodynamics (See Carnot Cycle) and converting to electricity does not improve efficiency. It makes it worse.
Their company is in trouble if they have a dead guy for a CEO.The internet at its finest :
It's a piston engine. How does it exceed any other piston engine on the road for thermal efficiency ? I think the promoters have also re-jigged the Carnot Cycle.
I recently saw on the internet that Bernie Madoff is actually the CEO behind this company.
No, no. That's how the promoters are controlling him . There's no worry about him ratting you out in a plea deal .Their company is in trouble if they have a dead guy for a CEO.
Reading the material, the claim is Mechanical efficiency.How does it exceed any other piston engine on the road for thermal efficiency ?
Why go back to a new type of IC engine when the world is trying to going forward with electric engines. Not very well in some cases I'll admit when we use dirty electricity, but if we can get clean electricity everywhere, we've got it made.
Always the same old problem, it seems too good to be true. Oh yeah, it is.
This is such an interesting debate to follow. It looks almost exactly like one of the many electric engine threads where someone puts forth an idea for going all electric and the posts blow up about how electric is all a shell game and we can't build a clean electric motor.it doesn't matter that it is configured differently. A heat engine is limited in its efficiency just by the laws of thermodynamics (See Carnot Cycle) and converting to electricity does not improve efficiency. It makes it worse.
If I understand correctly, this engine does not "drive" anything and there is no rotational output to connect to any load. What I saw was a very effecient motor-generator which produces electricity which is in turn used to drive things. Not sure if it make AC or DC but that really wouldn't matter much.It looks like a rethink of the old steam engine adapted to combustion fuels. Of courses, smaller and lighter is going to have a positive impact on a sailing vessel. The greater power of a two-sided combustion chamber would help in driving a larger prop at a slower rpm for better displacement driving power.
The engine shape also would fit well into the keel line of a boat. Is it quiet? Not having any rotating parts, it seems like vibrations would also be reduced, but I don't know. That's a lot of back and forth movement that has to be converted to rotational output. Perhaps a vertical orientation inside the keel would be a good arrangement.
-Will
