HELP!!! Just bought an older Hunter Passage. The previous owner (a number of years ago) caulked everything (and not well) and anything in sight - and I mean EVERYTHING. Clearly they thought there was a leak - but the clear caulking is cracked, shriveled and a plan old MESS. So, I researched and reviewed a ton of videos on replacing port lights, and thought we could do this easily. NOPE. The Hunter windows extend across gel coat (so it looks like large window on outside - but in the cabin, the window is much smaller). There are also little (what looks like it should be a screw hole - but there is clear silicone over the black caulk) and I'm nervous about digging into this.
The attached pic is just of the port light, but the polycarbonate that extends on either side was sloppily caulked all the way around the edges, so cleaning that up without getting the black caulk is impossible.
HELP!!! HOW does one remove these windows so they can rebed it, recaulk it, etc. I can't find instructions anywhere. All of our windows need to be redone. I'm hoping someone out there has instructions/a video or can show me how to do this! Any information will be greatly appreciated! Safe (dry) sailing
to start on my first fixed portlight removal. With your material and a library of additional material, I will eventually start in the most obscure location and corner of an out of sight fixed port. Good a place as any to start learning. Thanks again.
