Fuel Gauge
tb_gb
Jul 26, 2019
24
Hunter 380 Daytona Beach, Fl
On my Hunter 380, my fuel gauge always shows about half full....even when the tank is full, as it is now. Brand new gauge, so it has to be the sending unit. Does anyone have a recommendation for an "easy to install" replacement sending unit?
Thank you
A picture of your tank top showing the sending unit would be helpful.
This is one of the Moeller senders. (ELECTRIC SENDING UNIT W/REED SWITCH) I am using it on my boat. It has worked smoothly and with accuracy for about $90. Comes in different lengths too accommodate your tank.
Jan 4, 2006
7,770
What does the gauge say when the tank is close to empty ? Will anything cause the gauge to move off of half full ?
BarryL
May 21, 2004
1,126
Hey,
Before you start replacing things, be sure to check the wiring and the connectors. Over my 20 year's of boat ownership I can't even count the number of times that crimped on connectors are failed. Heat shrink, no heat shrink, good crimps, bad crimps, after a number of years they all seem to fail.
Check at the sender unit in the tank and at any panels, and, of course, at the gauge (which being new PROBABLY means it's OK).
Barry
RoyS
Jun 3, 2012
1,742
There are different sender unit designs. I like the ones that are flexible as there is often little room above the tank for the installation. You have to get one that has the proper depth to match your tank depth. Virtually all the sender mounting ports are the same universal design. Be careful with the orientation of the sender in the mounting port. It will only attach in one direction as the screw holes are not equally spaced.
Likes: Dalliance
Feb 10, 2004
4,245
Hunter 40.5 Warwick, RI
I have had repeated failures with the type of sender that uses an arm with a float. I have now switched to the vertical tube with internal read switches and after two years have had no problems.
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
Call WEMA. I replaced my sendinig units 11 years ago and all are still working fine. Waste can get stuck but after cleaning works fine.
Likes: JamesG161
Sep 26, 2008
792
Hunter 340 0 Wickford, RI
A word to the wise….I‘ve had my fair share of sender and gauge failures through the years. If you contact WEMA be certain you contact WEMA in the UK. The others were “authorized“ manufacturers of their products and the quality control was lacking.
This is a copy of my posting from June 22… There were more but this was the basic one you need for the link….
After my Wema Sensor fresh water float completely deteriorated, still trying to figure that one out. I spoke with Henry at Wema in the UK. He can outline the proper testing voltage and procedure for you. He is really very helpful. hello@wema.co.uk
He can better tell you the major difference in Wema USA and Wema UK. You want Wema UK.
I have an earlier posting from about 2 months ago “Wema Fresh Water Gauge Sending Unit” you can read here for some help.
Also from WEMA…
Here is how to test….
use this method, it comes from WEMA Gauges.
To test the sender simply:
  • Disconnect the two wires on top of the sender.
  • Remove the sender from the tank.
  • Connect the wires on the sender to a multimeter.
  • Set the multimeter to resistance [Ω ohms]
  • Move the float to the top of the sender and take a reading on the multimeter:
  • At the top of the sender (full) the resistance should be:
    • European specification - 190 ohms
    • American specification - 30 ohms
  • Move the float to the bottom of the sender and take a second reading:
    • At the bottom of the sender (empty) the resistance should be:
      • European specification - 0 ohms
      • American specification - 240 ohms
If you don't get the expected resistance reading on the multimeter then the sender is at fault and will need replacing.
Jan 4, 2006
7,770
Thanks, was not aware of the two different models.
I've had WEMA sensors in both the potable water and diesel fuel for 24 years. The WEMA holding tank sensor was trashed after the first two years. Unless the breakdown in QA has happened since 1998, I will assume mine are the European model
Sep 26, 2008
792
For me it wasn’t the gauge, sensor or wires. It was the float themselves. They just deteriorated. What was left of the floats, that I could handle without them falling apart in my hand, would register perfectly when moved up and down the tube.
That’s when I learned about the manufacturing differences. Imagine how shocked I was when I took this sensor out and saw that float. Bottom photo is original versus new.
7,770
Maybe that was their biodegradable model :yikes: !
Now I've GOT to check mine this summer whether UK or US model. How long were your units in service before those failed pictures were taken ?
  • Ha
792
I checked back through my log entries.
First started noticing level reading problems around 2010. Bear in mind, we’ve own our boat since new in January 2000, fresh out of the plant. I even have pictures of the build.
After 2010, the I was in denial for the next 2 years. You know, tapping the gauge, tapping the sensors, cutting the connections and crimping on new ones and hoping. And that worked for a while!
First sensors were replaced in 2012. And they worked for a while. The float’s didn’t look half as bad as your seeing now when I took them out. All was good.
Then I got the encore performance.
This year I found what you see in the photos.
I do have to say that I have never replaced the Waste Tank Sensor. And it works perfectly. Maybe because the float has a “protective” coating on it. And I don‘t really want to look and see.
I think it has a lot to do with with who was building that day and taking parts from which box of parts that were available.
For a while, I did think it was chlorine content in the water for the fresh water sensor, but that couldn’t be for the diesel fuel.
Just luck of the draw I guess.
JamesG161
Feb 14, 2014
8,086
Hunter 430 Waveland, MS
I had same issue with my Wema Fuel gauge as @sailcapt340 . I called Wema direct.
Ans: The old float was not coated correctly.
Result was a design change to prevent the float from ever adsorbing diesel.
My new one allowed me to calibrate my tank to ± 5 gallons in a 50 gallon tank.:biggrin:
Jim...
Sep 24, 2018
4,688
Catalina 30 MKIII Chicago
Not trying to derail this post but I have the same issue as the OP. When is it best to seek the original sending unit for ease of installation and when is it best to upgrade to a different style of sender?
Your display is showing "Half Full" when you suspect it is more or less than indicated.
First thing I would do is verify if the sender is at fault.
If at fault than replacement is an easy decision. If not at fault, you might choose to replace - or not.
What type of sender do you have?
Traditional?
Or new model
Sep 24, 2018
4,688
Traditional?
Or new model
The boat that has this issue is a 1995. It's wrapped up for the winter. To rephrase my question, is one design more reliable than the other?
