2000 Hunter 380 AC electrical problem
Nov 30, 2022
3
Hunter 380 Treasure Island, FL
When plugged in to a 30-amp receptacle at our home dock, with a split pigtail for the A and B buses on my 2000 Hunter 380, I get a reverse polarity light on the B bus when I turn on the air conditioning breaker and the main B-bus breaker in the aft lazarette in the cockpit trips. The A-bus stays connected and shows no problem.
Can anyone offer any suggestions about what might be causing the problem. It appeared suddenly after a two-day overnight cruise that was uneventful.
Thanks,
Don
JamesG161
Feb 14, 2014
8,004
Hunter 430 Waveland, MS
Same set up as my H430.
After 14 year, I had to replace those weaken breakers. Dual Breaker for A&B.
But as @Don S/V ILLusion noted, check from Boat to Dock.
Jim...
Likes: ggrizzard
Nov 30, 2022
3
Thanks for the suggestions. I'm also going to check the air conditioner cooling water filter to see if that is causing the breaker to trip, though I don't think that will address the reverse polarity issue, unless the way the system identifies reverse polarity is somehow messed up.
Don
JamesG161
Feb 14, 2014
8,004
This is my Lazaret Breaker Pair.
The Label I used to find the Replacement.
Only the B input was tripping like yours.
As you might see, you buy the Pair.
380 breaker
______
I think you mean Strainer.
How will you start your AC system without power?
No power, no AC cooling water flow.
Jim...
Nov 30, 2022
3
Jim, Thanks for the breaker info. Yes, indeed, I do mean strainer.
Don
Jul 23, 2009
926
The first thing to do is eliminate the splitter. Do you get a reverse polarity light with no loads running?
