Tongue Extensions
Jul 12, 2022
32
precision precision 18 chowan
tubing wall thickness will need to be stronger than necessarily thought for. There is a You tube video that shows an extension that was too light. Gentleman used a floor jack to see if he could lift the 3rd wheel off the ground.....his extension tubing bowed and bent under the load. Had he just used thicker walled tubing it probably would have held just fine. g'luck and let us know how it turns out
Tedd
Jul 25, 2013
777
TES 246 Versus Bowser, BC
Something's off, there. If you apply load to the tongue between the hitch and the point where the tongue attaches to the frame, then the bending load on the tongue is less than the normal bending load from the hitch. He must have done something else wrong. Maybe he forgot to decouple the hitch?
Anyway, yes, as I mentioned I'm doing a load and stress analysis to ensure the tubing is strong enough.
Dec 13, 2022
3
Victoria Victoria 18 Lavon
I purchased an 18 foot Victoria which came on a Magic tilt trailer with a tongue extension (not sure if it was OEM or not) but the extension disappeared while parked in the yard.
Fortunately the previous owner had sent me some pictures of the boat/trailer and one of them showed the extension so I had a local guy weld up a replacement for me.
Original from PO
My replacement
Tedd
Jul 25, 2013
777
That's a really interesting extension, @B-O-B'03 , I've never seen one like that before. Thanks for the idea!
Dec 13, 2022
3
Hi Tedd,
It is really simple to use, put the extension ball in the trailer coupler, slip the rear of the extension up the trailer tongue and put the pin through the lower hole to secure it.
Looking at the new one I could have had them build it with smaller square tubing and possibly a lighter gauge, it is definitely beefier than the original.
-Brian
Sep 24, 2018
3,384
Catalina 30 MKIII Chicago
Hi Tedd,
-Brian
That could also double as a winch mount to step the mast with minimal modifications
