- Oct 22, 2014
- 24,759
I'll hazard a guess here.
The shop when deciding to install the motor moutns thought it would be a good idea to put the 100's on the side that the motor will compress when the engine is advanced. This address the downward forces from the torque of the engine.
The greatest torque when the engine is put in gear and the throttle is advanced happens where the engine and transmission are located. The mounts would receive two forces at the mount. Up on one side and down on the other. I suspect that is the reason Yanmar states that the mounts should be 100 near the transmission/engine and 75 at the other end of the engine is because they are addressing both of the forces generated.
