Thanks for posting this diagram on the left! I never liked the way my single-line reefing was rigged. I am going to change to 2-line reefing except the luff line is going to be secured only at the mast, on a cleat that I have looking exactly like the diagram on the right!Ouch!! If you reefing line looks like the leftmost diagram below and you can remove the end cap then fish a wire tape with a messenger line attached to it under the end block and over the block nearest to the mast then out, then attach new reef line to the messenger line and pull it through.
I would but I don't have a reefing hook (ram's horn). I suppose it could be added. I don't mind going forward to the mast, but I could also lead the line from the luff back to the cockpit if I want to. I'll try to avoid an additional line in the cockpit for a while before I decide to do that. I've been using it as single line reefing and I'm not really satisfied with it, so I think I'll try something new!Scott. If you were inclined to leave the cockpit to reef, then you keep the single line in the boom and lower the main to the reef cringle and slip the cringle on to a reefing hook (a part of the goose neck).
Glad you got it working well. I hadn't heard back from you after you finished your setup.I followed @Hayden Watson s advice on setting up a single line reefing system. I attached Harkins Carbo Air Blocks to the reef points on the sail. By removing the friction of the line going through reef crinkles the tension at the tack and clew balances nicely. Another part of reducing the friction is not to not pull the luff reef tight to the boom. Leave it up 8 to 10” so the reef line does not rub on the sail.
Works well.
Sorry I didn’t follow up.Glad you got it working well. I hadn't heard back from you after you finished your setup.
Here is the block I use. It is a 40mm carbo block with a soft shackle to a welded SS ring. Works great. When I first set up my SLR I could not get the clew to come down due to the high friction. adding bearing blocks on both cringles made all of the difference. I also drop my halyard to a premeasured point where the reef tack cringle is about 6" above the boom. This keeps the lead to the tack block fair and free running.Thants for the tip, blocks make perfect sense! I’ll do i.
It is a game changer, right! I really like it when I am racing in a JAB race in the 20-25 knot range. I reef upwind and blow the pants off of all the unreefed boats and then I shake out the reef for the run and stay in the front. win, win!Sorry I didn’t follow up.
Yes, following your advice and procedure I can put in a reef in under 60 seconds without having to head into the wind. Tension is well balanced between tack and clew.
What a great use for a soft shackle. I tied the blocks on following the Harkin instructions. I wasnt tying soft shackles back then but since then I’ve made several so I’ll switch to them over the winter.Here is the block I use. It is a 40mm carbo block with a soft shackle to a welded SS ring. Works great. When I first set up my SLR I could not get the clew to come down due to the high friction. adding bearing blocks on both cringles made all of the difference. I also drop my halyard to a premeasured point where the reef tack cringle is about 6" above the boom. This keeps the lead to the tack block fair and free running.
