Johnson SFX compact toilet. $129.99 at Defender. Bought as ‘expedient’ alternative to restoring 1970s Raritan Compact head that was original to boat (sadly now lost).
1. All-plastic construction. Pump mounts using sheet-metal screws into blind holes in base. These screws must be kept in tension to ensure flapper valve/gasket does not leak. Any disassembly destroys plastic threads and causes a leak.
2. Undersized (metric) discharge elbow does not fit world-standard 1-1/2” hose. World-standard type-148 hose will NOT crush enough to seal, guaranteeing that any pumping will pour bowl contents out onto the cabin sole. (See photo of micrometer.)
3. No online service or tech help. No phone number to call. No e-mail contact. No warranty information. Johnson is a world leader in raw-water and bilge pumps. But none of them know anything about this toilet.
4. Defender is of no help at all. My experience is that they have no expertise about products they sell. Every time I’ve called to get help, I find I know more than they do; their advice seems silly. Why did I bother calling them then?
I attempted to remedy the discharge-elbow problem by substituting a Raritan elbow for the undersized original. Spent an hour gauging the fit and then sanding the plastic mounting flange to achieve a really good seal. The flange part of the joker valve is in fact the sealing gasket (same as with Raritan) so I ensured that was was soundly clamped.
Could not align hose to 90-degree elbow without removing pump; so removed pump from base, then could not align pump to base with hose connected; so unbolted toilet from shelf. Reassembled as required. (BTW I have like 40 yrs’ experience with installing and maintaining/rebuilding boat toilets.) Tested pump for leaks using river water before bolting down toilet. Seemed okay.
Pushed toilet into position to align mounting bolts. Dropped one into place. Toilet gushed water from pump base. Apparently the flexing of pump where screwed to base opened up a leak. Yet screws were properly done; surfaces met adequately.
This pump is NOT meant to be maintained or rebuilt since flapper valve doesn’t realign itself and sheet-metal screws rely on virgin factory holes in the plastic base. You take it apart, you'll replace the whole toilet. End of story.
I’ve left it bad reviews on Amazon and at Defender.
Realized this toilet will never be reliable, removed it, photographed it for this post, and will shortly fling it (never used) into the dumpster. Ordered new JABSCO toilet through distribution. Will install (with all new hose) tomorrow. Trip south delayed down to all this hassle - got nothing else done today while wrestling with this junk.
(Did I say how happy I always am to have SO MUCH MONEY that I can afford to spend it in good faith on things that don’t work and whose makers don’t care about their customers?)
You have been warned by a 50-yr veteran of the industry.
Lessons learned:
1. Defender is fine so long as you know EXACTLY what you’re buying and WILL NOT need tech help. Same as with Amazon.
2. I’ll never buy anything from Johnson again.
3. You get what you pay for.
Lessons learned:
and knowing you frequent this website, you MUST be aware of Peggie Hall's excellent work. Whether through her BOOK or her posts or her frequent contributor status here, I find it remarkable that you are unaware of her steady and persistent encouragement to boaters that the best marine manual head is made by Raritan.
