I'm way to lazy to do a vector analysis but I'd guess the topping lift is the heavy lifter here. Just wish he'd put the attachment for the Xmission directly under the attachment for the topping lift. Hope he remembers next time.I said good idea with Boom Lift, but not so good where all that weight pushes on his mast.
If you look at the picture I posted in post #20, the main halyard takes the weight, which I think is much better than the topping lift.I'm way to lazy to do a vector analysis but I'd guess the topping lift is the heavy lifter here. Just wish he'd put the attachment for the Xmission directly under the attachment for the topping lift. Hope he remembers next time.
So many people get freaked out about using the boom to lift out an engine. My C30 has a loose footed main with the standard 6:1 mid-boom main sheet. On a beat in 18-knots, I need to put significant effort into the 16ST winch to flatten the main. That 200lb transmission (or my 550-lb universal) is nothing in comparison to the normal loads from sailing.I'm way to lazy to do a vector analysis but I'd guess the topping lift is the heavy lifter here. Just wish he'd put the attachment for the Xmission directly under the attachment for the topping lift. Hope he remembers next time.
But in the case Ralph is talking about, the topping lift is carrying the load, which may or may not be up to the job. It might be fine, but I'm not sure that I would want to rely on it.So many people get freaked out about using the boom to lift out an engine. My C30 has a loose footed main with the standard 6:1 mid-boom main sheet. On a beat in 18-knots, I need to put significant effort into the 16ST winch to flatten the main. That 200lb transmission (or my 550-lb universal) is nothing in comparison to the normal loads from sailing.
I partially agree with that. If you know that the topping lift is good, I would not be concerned but would probably still use the main halyard because then I can raise and lower the boom for more reach.But in the case Ralph is talking about, the topping lift is carrying the load, which may or may not be up to the job. It might be fine, but I'm not sure that I would want to rely on it.
True. With the method shown in my picture, I did use the topping lift to raise the boom up at an angle, which proved helpful when I had to swing the boom over the side of the boat to set the engine into a dock cart. But again, the main halyard was taking the load. Worked very well.I partially agree with that. If you know that the topping lift is good, I would not be concerned but would probably still use the main halyard because then I can raise and lower the boom for more reach.
If you look closely at the Picture of John, he used both the Halyard and Topping lift on his Boom.the topping lift is carrying the load,
Time flies when you're having fun !PS: I corrected my 1.5 hrs to 1.5 years since I started my 50 HP Volvo Penta Engine.
I like your use of the single block attached to the come-along to redirect the main halyard down to the engine. I will need to remember that one.True. With the method shown in my picture, I did use the topping lift to raise the boom up at an angle, which proved helpful when I had to swing the boom over the side of the boat to set the engine into a dock cart. But again, the main halyard was taking the load. Worked very well.
Prior to installing this little devil, I used to religiously replaced my Racor primary filter on an annual basis. Not no more. However, after 5 years (at a cost savings of over $100) of the red "follower" needle not moving beyond -2 inHg, I decided out of an abundance of caution, to replace it. In following the theme of this thread and thus not intentionally stealing it, I ask the question: Does there come a time when the "high-grade cellulose and synthetic nanofibers" filter media of a Racor finally give up the ghost? IE Regardless of what the red follower needle tells me should the filter be replaced after "X" number of years/engine hours?
I doubt fiber breakdown is ever a problem."high-grade cellulose and synthetic nanofibers" filter media
Not quite. These clowns are actually looking for :There you have it. 500 hours.
Your appreciation of cheapness is to be commended .I vote for Ralph.
Many many years ago, a very wise man once told me “No cheap is not associated with boats, I fear.”Your appreciation of cheapness is to be commended .
Nope. Nobody never talks to me.Hmmm or was it jssailem 38 minutes ago in a PM?
